4 inch Dp, AC?
Old Jan 10, 2005 | 10:24 AM
Tinker219's Avatar
Default 4 inch Dp, AC?
Im building a prototype manifold/DP combo thats pretty much un-heard of. It allows the use of a full 4" downpipe, in CONJUNCTION with AC on all B series motors, in EG/EK/DC chassis, possibly some of the EFs w/some modifications.
Pictures soon, but is there any interest for something this extreme? The answers will determine pricing, and if I actually begin producing these, or keep them one-offs.
I guess to keep this more tech related, has anyone seen a 4" downpipe used with AC???
Old Jan 10, 2005 | 10:27 AM
PrettyLude's Avatar
if you build it they will come, lol post some pics up cody when ur done
Old Jan 10, 2005 | 10:29 AM
DaveF's Avatar
Default Re: (PrettyLude)
ohhhh the possibilities... 700+hp with the ac on...
LOL goodluck cody. sounds like its gona be a tight fit in there.
Old Jan 10, 2005 | 10:30 AM
11psiTurboSI's Avatar
Default Re: (Dturbocivic)
When 3inch isn't enough
Old Jan 10, 2005 | 10:38 AM
fipracing_com's Avatar
Default Re: 4 inch Dp, AC? (Tinker219)
I have a 3" DP on now with A/C and i just dont know how in the world you could fit a bigger DP on the 99-00 SI's. Sure id like to see pictures of a 4" dp on a 99-00 civic with a/c, if you can do it.
Old Jan 10, 2005 | 10:48 AM
Tinker219's Avatar
Default Re: 4 inch Dp, AC? (fipracing_com)
Ive done a lot of thinking out side the box with this setup. With a 4" Downpipe, everything is contained within 7" from the head-flange surface of the block. AC line/condeser adjusting will probably be necessary, but it should be trivial compared to the gains from 4" of pure madness(I thought she wanted 12" ).
Old Jan 10, 2005 | 10:56 AM
b18bEG's Avatar
you are a madman.... id love to see it though
Old Jan 10, 2005 | 11:01 AM
DefiantGSR's Avatar
Default Re: (b18bEG)
Give it a shot. If it works, you'll be phucking rich.
Old Jan 10, 2005 | 11:22 AM
illi Adik's Avatar
Default Re: (DefiantGSR)
Im down.
Old Jan 10, 2005 | 11:51 AM
Tinker219's Avatar
Default Re: (Jackson4Door)
Good response's, expect this to market by spring then!
Old Jan 10, 2005 | 12:18 PM
yellowturbo's Avatar
I dont know if a 4 inch DP would provide good gain on a street setup... I mean on a 300-350 whp or so setup, like mine ???
I have a 2.5 inch DP right now and I was considering the fabrication of a 3 inch this winter... I run a Lovefab SST with no AC. Should I go 3.5 inch or 4 inch if it fit ??
If the gain are there you should do it Cody... but I cant say if it worth it or not ?
Old Jan 10, 2005 | 12:41 PM
Rod.'s Avatar
Default Re: (yellowturbo)
4" dp w/ ac ...I like to see this
I have 3" w/ ac I cant even put a finger between the two
Old Jan 10, 2005 | 01:04 PM
DIRep972's Avatar
Smarter than you
That'd be awesome. I believe you can make a 4" downpipe work w/ the hytech header and keep AC. Or well, at least Cheesefrog was going to try too. Is this manifold also going to give wastegate primary flow? I think you should make it.
Old Jan 10, 2005 | 01:49 PM
Tinker219's Avatar
Default Re: 4 inch Dp, AC? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">That'd be awesome. I believe you can make a 4" downpipe work w/ the hytech header and keep AC. Or well, at least Cheesefrog was going to try too. Is this manifold also going to give wastegate primary flow? I think you should make it. </TD></TR></TABLE>
Yep, primary flow wastegate, 4-2-1, top mount turbo design Making anymore sense yet? Yes radiator hose work will be required, but thatll be an easy option for the consumer to purchase, or even easier to make him/herself.
Old Jan 10, 2005 | 01:52 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, primary flow wastegate, 4-2-1, top mount turbo design Making anymore sense yet? Yes radiator hose work will be required, but thatll be an easy option for the consumer to purchase, or even easier to make him/herself.</TD></TR></TABLE>
Damn, sounds a lot like what I was thinking of making for my car at some point. Good luck with it.
Nobody will complain about ripping it off someone else, but be ready for copies of it to start showing up.
Old Jan 10, 2005 | 01:55 PM
Lucky_Smurf's Avatar
Default Re: 4 inch Dp, AC? (one.6)
This would be interesting to see for sure Cody. Way to go, keep coming up with new ideas. One suggestion would be to offer a "kit" with the manifold of stuff you would need in order to get it to fit you know. Keep up the good work.
Old Jan 10, 2005 | 02:04 PM
DIRep972's Avatar
Smarter than you
ahhh, nice. I am trying to picture it in my head. sounds very, perfect.
Old Jan 10, 2005 | 02:15 PM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one.6 &raquo;</TD></TR><TR><TD CLASS="quote">
Nobody will complain about ripping it off someone else, but be ready for copies of it to start showing up. </TD></TR></TABLE>
thank you, and yes there will probably be many copies.
Yep, a complete kit will be ready by spring, including turbo, all the goodies.
I dont know about "perfect", but provided it fits as well as Im hoping on customer's cars, it could be a completely new direction
Old Jan 10, 2005 | 02:21 PM
DIRep972's Avatar
Smarter than you
I dont know about "perfect", but provided it fits as well as Im hoping on customer's cars, it could be a completely new direction </TD></TR></TABLE>
Ahah tubular, no boost spikes, and 4" downpipe w/ AC.. How much more spoiled do they need to be?
Old Jan 10, 2005 | 02:26 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Ahah tubular, no boost spikes, and 4" downpipe w/ AC.. How much more spoiled do they need to be? </TD></TR></TABLE>
Made from inconel with slip-fit collector?
Old Jan 10, 2005 | 03:20 PM
LostSolVTEC's Avatar
if it's put into produciton, do you have any price guestimates?
Old Jan 10, 2005 | 04:33 PM
Full-Race Geoff's Avatar
good to see you experimenting with different ideas man. Ill post pics of the new manifold i built for my civic, no way is it AC compatible, but definately a 4-2-1 style, which can be done a ton of different ways. good luck
Old Jan 10, 2005 | 05:40 PM
DIRep972's Avatar
Smarter than you
Made from inconel with slip-fit collector? </TD></TR></TABLE>
lol. ok, good point.
Old Jan 10, 2005 | 05:49 PM
Casey's Avatar
sounds awesome cody cant wait to see the finished product
Old Jan 10, 2005 | 05:55 PM
Ri5e's Avatar
Sidewinder with 4 inch downpipe
