Quick DRAG manifold question. (stud size and pitch)
Are the studs the DRAG manifolds accept 10x1.50? Simple yes or no will do. Thanks.
Phil
Phil
Re: Quick DRAG manifold question. (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Are the studs the DRAG manifolds accept 10x1.50? Simple yes or no will do. Thanks.
Phil</TD></TR></TABLE>
No. They are 10mm x 1.25
Re: Quick DRAG manifold question. (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
No. They are 10mm x 1.25 </TD></TR></TABLE>
Where did you find yours at Matt? ATP-turbo only sells 10x1.50. I pm'd Stan( @ fast-turbo) and am waiting for his reply.
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Mine came with the DRAG kit.</TD></TR></TABLE>
Thanks Matt. That's what I figured. Bump for some help.
try home depot or any small hardware store... down here in miami there is this cool place called mitchell's... they have any nut, bolt, screw you could think of! and they're cheap! just show up with a sample or measurements and viola!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">I just checked our stock at work and we have all those sizes. I'd check around, should be some out there.</TD></TR></TABLE>
Will do. There is a killer hardware store here in town. I'll check there. Thanks.
I bought a used Drag manifold and it took me forever to find the right hardware for it!
I ended up buying stainless steal studs from Fast-Turbo.com for $20...
It was expensive but those studs have to be strong to withstand all the heat and weight of the turbo...
Re: Quick DRAG manifold question. (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">I bought a used Drag manifold and it took me forever to find the right hardware for it!
It was expensive but those studs have to be strong to withstand all the heat and weight of the turbo... </TD></TR></TABLE>
so...............what was the size and pitch? I looked on fast-turbo and there isn't any info on the studs up on his site right now.
Phil
Phil
I don't remember exactly what thread and pitch size they were... but if you PM "Flamenco-T" on here you can ask Stan (the Fast-Turbo.com guy)...
He will know for sure the size of all that hardware...
SIred91
Southwest
131
07-02-2008 08:05 PM
Full-Race Henry
07-23-2003 09:41 AM
