HELP!!!!! mandrel bent pipes from kteller.com what sizes to get
Location: home of Marciano/Haggler, city of champions, MA
im just a little confused at what sizes to get for my intercooler pipes. they make 45-90-180 degree bends. i have a 94 accord 94 h22. i only need the measurements from turbo to intercooler side, not intercooler to throttle body. thanks. it must clear power steering, ac, and stock radiator. thanks for your help.
Re: HELP!!!!! mandrel bent pipes from kteller.com what sizes to get (h22boy)
If you have the ability to weld mild steel (with any crappy 110v flux-core MIG), just do what I do and buy 180° bends. You can cut the bends into whatever angles you need for the pipes. Often more than 1 radii of bend is available, in which case I buy the smallest radius for charge pipes and downpipes, and the larger radius for building an exhaust, since you generally have a lot more manuevering room under the car.
noluckracing
Welding / Fabrication
07-25-2010 09:12 AM
