apex turbo timer
Old Jan 8, 2005 | 07:13 PM
honhatchisbak's Avatar
Default apex turbo timer
i just put in the apexi turbo timer and there is a setting where you can set the a/f and o2, where am i suppose to get it at i think it goes by incriments of 10, cause the way it is now its always showing that im leaning out even at idle, it goes red when i barely step on the gas, its for gsr block, with b16a head, any help would be welcomed, thanks
Old Jan 8, 2005 | 07:45 PM
CivicEJ1's Avatar
Default Re: apex turbo timer (honhatchisbak)
I have one too and it's a narrow band a/f ...junk.. all I need it for is the small size and read volts and turns my car off in ??? mintues...
Get yourself a wideband a/f gauge....
Old Jan 8, 2005 | 09:52 PM
RNPoo7's Avatar
I noticed that those timers say that it dedecuts how hard you have been driving and times the timer according to yoru driving. Is that bs or does it actually estimate it nicely?
Old Jan 8, 2005 | 10:14 PM
V-SPEC 1's Avatar
did you wire up the correct wire to the 02 signal? check that. it should read just fine.
Old Jan 9, 2005 | 09:01 AM
Default Re: apex turbo timer (boostedb20vtec)
i know for sure i wired up the o2 correctly, but just tryin to figure out how to set the a/f
EvilRB
Apr 11, 2013 09:49 PM
monicle
Jan 7, 2004 06:07 AM
sinfulDB1
Oct 30, 2003 10:53 PM
Maverick77
Dec 31, 2002 12:38 PM
TurBoXBirD16
Oct 14, 2002 02:14 PM
