gasket size
Old Jan 8, 2005 | 07:08 PM
honhatchisbak's Avatar
Default gasket size
i got b18c block, with b16 head, with aebs studs, i want to get a thicker head gasket, i heard cometic is the best, i know they make different thicknesses in the head gasket should i just get the thickes one i think its like 85mm or something, someone let me know, thanks
Old Jan 8, 2005 | 07:13 PM
X-Mazda 3 Racer's Avatar
Default Re: gasket size (honhatchisbak)
Well, just for your clarification, the 85 mm size you are talking about refers to the bore size. Gaskets usually range in numbers like .032". If you have a stock block, then you would want an 81 mm gasket in your desired thickness. Hope that helps you a bit.
Old Jan 8, 2005 | 07:15 PM
Default Re: gasket size (GoldenEagleMfg.com)
yes i just figured that out, sorry
slow_ls
Aug 23, 2007 02:12 PM
Vt3c_eg
May 31, 2007 10:59 AM
LSVtechnologytur...
Dec 31, 2004 01:23 PM
Fatty_1775
Nov 29, 2002 10:25 AM
Crazy DA
Sep 21, 2001 12:08 PM
