Intake Mani and TB sizing???'s
Old Jan 6, 2005 | 07:54 PM
pubestripe's Avatar
Default Intake Mani and TB sizing???'s
i have a jg victor x mani and am looking to get a throttle body for it... now i am a little confused as to what i should get regarding TB size. I believe that jg mani is 65mm?? so should i get a 65mm TB or get the mani ported to 70mm and get a 70mm TB? please help!!!! thanks...
Old Jan 6, 2005 | 08:04 PM
Adriano's Avatar
Default Re: Intake Mani and TB sizing???'s (pubestripe)
It depends how much power you want. For under 350whp, it wont make much of a difference. Also depends on the size of your i/c pipes. No sense in getting a 70mm (3 inch) if your piping in only 2.5 (65mm)
Adriano
Old Jan 6, 2005 | 08:17 PM
pubestripe's Avatar
Default Re: Intake Mani and TB sizing???'s (brryder)
that is what i was thinking... i mean, i have a full race kit, but my ic piping is only gonna be 2.5 inch, so it would really be pointless for the airflow to open up 5 more millimeters for no reason really... im thinking i should just keep the 65 straight through...
Old Jan 6, 2005 | 08:20 PM
adictionbass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">that is what i was thinking... i mean, i have a full race kit, but my ic piping is only gonna be 2.5 inch, so it would really be pointless for the airflow to open up 5 more millimeters for no reason really... im thinking i should just keep the 65 straight through...</TD></TR></TABLE>
Old Jan 6, 2005 | 10:07 PM
EPthrizzle's Avatar
Default Re: Intake Mani and TB sizing???'s (adictionbass)
interesting. i figure why not go 70mm. same price right? maybe more surface are due to throttle plate just being there?
Old Jan 7, 2005 | 09:14 PM
pubestripe's Avatar
Default Re: Intake Mani and TB sizing???'s (EPthrizzle)
but really, isnt it pointless to go from the 2.5 inch to the 3 inch, and then back down to the 2.5??? that is really pointless IMO... y make a larger area for the air to go, only to find out that it needs to be compressed again back down to the 2.5?
Old Jan 8, 2005 | 10:30 AM
dumpeDc2's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">but really, isnt it pointless to go from the 2.5 inch to the 3 inch, and then back down to the 2.5??? that is really pointless IMO... y make a larger area for the air to go, only to find out that it needs to be compressed again back down to the 2.5?</TD></TR></TABLE>
so going from 2.5intercooler piping to a larger throtle body to a event bigger intakemanifold runner would be bad? what abought the throtle plate with that there is dosent flow like a a true 2.5inch pipe
Old Jan 8, 2005 | 12:49 PM
Casey's Avatar
Default Re: Intake Mani and TB sizing???'s (DumpeDc2)
well. if your i/c piping is 2.5" which is about 63.5mm which means youd have to have a larger tb for it to be "equal" because you need to take the butterfly into consideration as a restriction, a small one but its still there.
Old Jan 8, 2005 | 03:32 PM
pubestripe's Avatar
Default Re: Intake Mani and TB sizing???'s (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">well. if your i/c piping is 2.5" which is about 63.5mm which means youd have to have a larger tb for it to be "equal" because you need to take the butterfly into consideration as a restriction, a small one but its still there. </TD></TR></TABLE>
exactly, so therefore 65mm is a perfect TB size...
edsperformance
Mar 17, 2012 05:10 PM
CRXherbie91
Jul 28, 2010 04:48 PM
hmongyaj87
Apr 4, 2008 12:37 PM
john d ftw
Aug 29, 2006 10:53 PM
Blown90hatcH
Aug 30, 2002 12:22 AM
