td04???
Old Jan 8, 2005 | 10:28 PM
hatchracer02's Avatar
Default td04???
ok my friend with a 2003 wrx hooked me up with this stock turbo (td04) and i was gonna build a custom turbo kit. my question is does anyone know what the wastegate will open up ???
thanks
Old Jan 8, 2005 | 11:13 PM
mrspeaker's Avatar
Default Re: td04??? (hatchracer02)
It's a TD04L-13T
I think the internal wastegate is set at 13.5 lbs
Old Jan 9, 2005 | 09:42 PM
Default Re: td04??? (Mrspeaker)
with the wastegate set so high could i use a boost controler to turn it down to be safe on my d16z6??
Old Jan 9, 2005 | 09:57 PM
CivicEJ1's Avatar
Your boost controller will only go as low as what your wastegate spring is set at.
Old Jan 9, 2005 | 11:04 PM
djfob's Avatar
The wastegate is set to 7 psi. It only runs higher boost because of a selenoid.
Old Jan 10, 2005 | 04:40 AM
93turbo16's Avatar
Default Re: (djfob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djfob &raquo;</TD></TR><TR><TD CLASS="quote">The wastegate is set to 7 psi. It only runs higher boost because of a selenoid.</TD></TR></TABLE>
Probably right, DSMs do the same thing.
Old Jan 10, 2005 | 05:13 AM
Buzzbomb's Avatar
Default Re: (djfob)
Yes, this is correct.
Funanin
Jan 10, 2008 05:51 AM
N20civicB18
Dec 27, 2006 09:22 AM
gsrt
Oct 16, 2006 11:24 PM
seeeya04
Dec 3, 2005 04:34 AM
blackcivic44
Feb 1, 2005 07:45 PM
