where do vacuum lines go on electronic boost controller?
Old Jan 8, 2005 | 11:16 AM
egvtec's Avatar
Default where do vacuum lines go on electronic boost controller?
ok i have three vacuum lines i know one goes to wastegate one to the intake manifold and one to a vacuum source. where is a good vacuum source? and which lines go to what? i noticed two of three have theese little things on the lines halfway look like little plastic u.f.o.s lol
i have no directions with mine it is a greddy profec. also there is a little nipple on the box in the engine bay do i send anything to this? any help appreciated
Modified by egvtec at 8:42 PM 1/8/2005
Old Jan 8, 2005 | 07:38 PM
Cee_mon's Avatar
Default Re: where do vacuum lines go on electronic boost controller? (egvtec)
those are air filters....
1 thin line with air filter goes to box inside car from vaccum source.
1 thick line goes from black box (OUT) to wastegate.
1 thick line goes from black box (IN) come from a vaccum source.
Vaccum source can be in lots of different spots, brake booster, some turbos, msot vaccum lines from engine.
Old Jan 8, 2005 | 07:58 PM
egvtec's Avatar
Default Re: where do vacuum lines go on electronic boost controller? (Cee_mon)
ok well its working but my boost is not turning up. when i adjust the controller. is this because the top bolt on my external wastegate is missing does there need to be pressure in the wastegate at the top where that bolt goes? or does this not matter. its the bolt on the deltagate that goes in the center of the wastegate at the top thanks.
Old Jan 9, 2005 | 09:25 AM
Cee_mon's Avatar
My write up there was for internal wastegate and is the way i have mine setup. You will need to find someone with it on a external wastgeate setup so you know what nipples to use off the wastegate.
bmbarnum
Apr 6, 2011 07:54 AM
tundra2000
Sep 26, 2010 06:42 AM
alacard
Apr 5, 2010 07:19 PM
2ndchirp
May 20, 2009 08:12 PM
streetrage
Oct 14, 2003 10:52 PM
