hondata question
Old Jan 10, 2005 | 10:54 AM
GReddy SI's Avatar
Default hondata question
right now i have a 17 VSS - speed sensor cel on my car , but the car doesnt boost . does hondata allow boost when i have this cel on my car?
Old Jan 12, 2005 | 10:17 PM
GReddy SI's Avatar
Default Re: hondata question (GReddy SI)
anyone know?
Old Jan 12, 2005 | 10:38 PM
H.A.R.T B18C1EG6's Avatar
Good question.... i would like to know also because I have a CEL for knock sensor
Old Jan 12, 2005 | 10:54 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">right now i have a 17 VSS - speed sensor cel on my car , but the car doesnt boost . does hondata allow boost when i have this cel on my car?
Vehicle Speed Sensor is on the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Good question.... i would like to know also because I have a CEL for knock sensor </TD></TR></TABLE>
Why dont you try replacing the knock sensor????
Old Jan 12, 2005 | 10:58 PM
Default Re: hondata question (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you try replacing the knock sensor????</TD></TR></TABLE>
I want to but dam 160bucks for a new one from honda.... I will get another one but just curious, can hondata be tuned or even boost with a CEL?
Old Jan 12, 2005 | 11:03 PM
IVANITR's Avatar
I know that you can disable the knock sensor through the hondata but not sure on the vss.
Old Jan 13, 2005 | 01:07 AM
TeStUdO's Avatar
Default Re: (IVANITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVANITR &raquo;</TD></TR><TR><TD CLASS="quote">I know that you can disable the knock sensor through the hondata</TD></TR></TABLE>
This is true, or just get a p28 ECU
Check the VSS to see if it is bad. To check it locate it on the transmission. It is up on the top.
1. Check for voltage at the electrical connector of the VSS. The positive wire on my Civis is black/yellow, the signal wire is blue/white and of course the negative is blck. Check to make sure the positive wire is getting voltage. If not you have a open circuit betwwen there and the fuse box
If you are getting voltage to the electrical connector on the VSS proceed to step 2
2.Place the front of your car on jackstands. Locate the signal wire on the VSS (It is blue and white on my Civic). Connect the positive lead of a voltmeter to the signal wire and the negative side of a voltmeter to a good ground. Hold one wheel still while turning the other wheel. The voltmeter should pulse btween 0-5 volts. If not replace it.
Hope this helps you
djsire
Mar 26, 2007 06:29 AM
genocide43110
Feb 20, 2007 09:37 PM
J337_UNIT
Apr 30, 2004 08:08 PM
g5r
Sep 3, 2003 10:16 AM
