Turbo b18b problem
Old Oct 1, 2005 | 08:26 AM
Novtecdohc's Avatar
Default Turbo b18b problem
I finally got my teg boosted... Its really fast over stock of course.. My problem is that when im in 1st and 2nd gear, the car make boost but in 3rd and 4th it make a **** load of boost and the car hauls ***.... Cant under stand why its not that fast in 1st and 2nd gear
Im using:
Garrett T3T4 60/63 57 trim turbo
8psi Internal wastegate from a saab
Turbular T3 Manifold
12:1 Vortec FMU
255lph Inline pump
4 check valves
Old Oct 1, 2005 | 08:28 AM
boostjunkie757's Avatar
you arent tuned....thats why...
Old Oct 1, 2005 | 09:07 AM
Novtecdohc's Avatar
Default Re: (boostjunkie757)
dont see how beening tuned has anything to so with it .. but ok
Old Oct 1, 2005 | 09:35 AM
Cyphear's Avatar
is it building as much boost in 1st/2nd?
Old Oct 1, 2005 | 09:41 AM
blackeg's Avatar
Default Re: (Cyphear)
tuned can have a lot to do with everything....
how much boost is a shitload? technically you should be right around 8 psi the whole time
for your case, heres a few possibilities:
your wastegate is creeping/isnt able to hold the boost back. that turbo larger than the saab turbo, and it is gonna be holding back a lot of air to keep you at 8 psi, so maybe the wastegate creeps up a bit. it does happen with internal gates.
maybe the boost in 3rd and 4th is what you are actually making, and you arent hookin up as well in 1st and 2nd and therefore there isnt as much load on the motor, though if that were to effect you, i dont think it would be drastic at all.
i think we need a lil more info to help you better
Old Oct 1, 2005 | 09:53 AM
well, first gear in hondas is generally useless...you should spin through it. but if youre running on an FMU and a fuel pump, youre gonna be lucky to be seeing a 12:1 afr throughout your rpm range. cars that are hondata/uberdata/crome/neptune/emanage programmed, will run richer down low to spool quicker....youll get quicker spool and more power throughout your powerband because you can adjust the AFR. as well as the timing. ditch the fmu....keep the pump, put some injectors in her, and get some type of tuning.
Old Oct 1, 2005 | 10:30 AM
wantboost's Avatar
Who is Mr Robot?
12:1 fmu does not mean 12:1 afr
it means that for every psi of boost it ups fuel pressure 12 psi... so 8 psi = 96psi + 42psi base fuel pressure = 138psi of fuel pressure at the injectors.... hes running pig rich
Old Oct 1, 2005 | 10:31 AM
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">12:1 fmu does not mean 12:1 afr
it means that for every psi of boost it ups fuel pressure 12 psi... so 8 psi = 96psi + 42psi base fuel pressure = 138psi of fuel pressure at the injectors.... hes running pig rich</TD></TR></TABLE>
i never did understand how that **** worked...
either way, i said he would have been lucky to see 12:1 afr....and that isnt running rich....but theres still some room for more power. i didnt know exactly what afr he would be at.....but it would be 12 or less to one..
Old Oct 1, 2005 | 10:33 AM
Blaze45's Avatar
Brrraaaap!
How much boost are you actually running? If its 8psi then it should practically spool competely in 2nd gear. Now 15psi on the other hand.... lol Id generally be fully spooled by the end of 2nd. Have you retarded the timming at all?
Old Oct 1, 2005 | 10:36 AM
TurboCoop's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">your wastegate is creeping/isnt able to hold the boost back. that turbo larger than the saab turbo, and it is gonna be holding back a lot of air to keep you at 8 psi, so maybe the wastegate creeps up a bit. it does happen with internal gates.</TD></TR></TABLE>
Just cause its an 8psi wategate doesnt mean its 8psi on all turbos, it kept the little *** Saab turbo it was designed for at 8psi, but with your big turbo its probably creeping more and more in higher gears. And FMU's suck for future reference.
Old Oct 1, 2005 | 10:53 AM
JDMs1eeper's Avatar
post more info
EDIT: a boost gauge is your friend
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 &raquo;</TD></TR><TR><TD CLASS="quote">
either way, i said he would have been lucky to see 12:1 afr....and that isnt running rich....but theres still some room for more power. i didnt know exactly what afr he would be at.....but it would be 12 or less to one..</TD></TR></TABLE>
hes well into the 10 afr's at this point
Old Oct 1, 2005 | 10:55 AM
hes well into the 10 afr's at this point</TD></TR></TABLE>
just like my 99 ls/turbo...
made all kinds of noise, but wasnt quicker than mid 14's...
ChuckyStaytuned
Nov 4, 2014 10:18 AM
j.packsb
Sep 29, 2010 06:05 AM
JayDiem_k20_Dc5
Jun 6, 2006 07:52 PM
xstalkrx
Mar 1, 2003 06:18 PM
