car randomly dies sometimes??
Old Oct 5, 2005 | 09:39 AM
fanta!'s Avatar
Default car randomly dies sometimes??
coming to a stop at a light or stop sign the car will start to idle really low and eventually shut off (sometimes) ??
other times when it doesnt die, the idle will start to drop and the engine will sound less loud (can tell from open DP)
doesnt seem like anything is wrong, oil level is good, etc.
Old Oct 5, 2005 | 09:46 AM
BoostGoneWild's Avatar
Default Re: car randomly dies sometimes?? (fanta!)
what ecu are u running cause sometimes its a sign that you are running a little lean in iddle or check your fuel pressure
Old Oct 5, 2005 | 04:08 PM
fanta!'s Avatar
Default Re: car randomly dies sometimes?? (BoostGoneWaild)
p72
Old Oct 5, 2005 | 05:26 PM
Civicman86's Avatar
What fuel mani are you using? Are you tuned?
Old Oct 5, 2005 | 07:58 PM
D@nnY's Avatar
if you can turn up the idle air control duty cyle and raise the idle... also make sure you dont hav e abd main relay or else the fuel pump can randomly shut off
Old Oct 5, 2005 | 08:04 PM
debogsr's Avatar
Default Re: (D@nnY)
man i got the same problem.
BUmp for an answer
im P-72 tuned with hondata
Old Oct 5, 2005 | 08:55 PM
Turbo_Mike's Avatar
Default Re: (debogsr)
i had a similar problem and it was a bad ignitor. but my car was also bucking at high rpms
Old Oct 5, 2005 | 10:30 PM
AspectIndustries's Avatar
Default Re: (MIKE JONES)
Were you OBD2?
Old Oct 6, 2005 | 04:35 AM
Turbo_Mike's Avatar
Default Re: (synik)
no obd1
Old Oct 6, 2005 | 06:22 AM
Default Re: (synik)
Hmm, IACV clogged? Take it out and apart, and brake cleaner that sucker!
Old Oct 6, 2005 | 07:04 AM
red02s2k's Avatar
when i put my jg intake manifold on and my str 70mm throtle body on my car it started doing the same thing so i hope if i go up to the shop this weekend and get my car tunned it will fix my problem
Old Oct 6, 2005 | 07:04 PM
fanta!'s Avatar
Default Re: car randomly dies sometimes?? (red02s2k)
im tuned on hondata as well. im sure its not a tuning problem
Old Oct 6, 2005 | 11:21 PM
debogsr's Avatar
bump
Old Oct 7, 2005 | 07:34 PM
fanta!'s Avatar
Default Re: car randomly dies sometimes?? (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Oct 8, 2005 | 10:59 AM
fanta!'s Avatar
Old Oct 8, 2005 | 12:10 PM
debogsr's Avatar
Ive talked to a few of my friends, and they all say they have this problem, but not as bad as mine. RPM's always drop a little on the downrev, but Ive never seen it as bad as the car will die like mine sometiems does.
Old Oct 8, 2005 | 12:46 PM
planeman01's Avatar
mine does this, i'm going to try cleaning the eacv
Old Oct 8, 2005 | 03:20 PM
integra686's Avatar
mine was doin the samething. i jus replaced my distributor and wires and spark plugs and never did it again. but wen my car died and i tried to start it again it would only crank and not kick over i would have to wait about 2 or 3 minutes b4 i could start it again. i did this about 4 months ago and still hasn't stalled on me so... to each there own. even the simple things do alot.
eriki
Feb 5, 2017 09:15 PM
Koko4
Oct 9, 2014 06:34 AM
atarigamer01
13
Jun 24, 2009 10:25 AM
garyc17
Oct 21, 2007 09:48 PM
quikrpm'z
Jan 31, 2002 06:16 PM
