DSS Stage 5 Install Question
Old Oct 2, 2005 | 06:06 PM
FredoSP's Avatar
Default DSS Stage 5 Install Question
I got some fitment questions about these axles.
1. Are the splines supposed to go all the way through the hub? I assumed they have to, but this is as far as I get. I think the lip is hitting the back of the knuckle (the thing that connects the upper and lower control arms + axle). Here are some pics for reference. Any help is appreciated.
This is the view from the back of the spindle.
In this pic you can see where it went in by the amount of anit sieze on there
Old Oct 2, 2005 | 06:21 PM
97turbols's Avatar
Default Re: DSS Stage 5 Install Question (FredoSP)
not sure what spindle you're using but this came off the dss website about the stage 5:
"the outer c.v. is so large it has to be used with either a 92+ c.v. spindle with abs or a 94+ Integra spindle (wheel bearing I.D. 1.693)"
not sure if that helps at all.
Old Oct 2, 2005 | 06:39 PM
FredoSP's Avatar
Default Re: DSS Stage 5 Install Question (97turbols)
you have a point .. hmm i could have over looked this ... grrrrrrrr I guess I'll call Lee or Frank at DSS, thanks
Old Oct 3, 2005 | 04:49 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols &raquo;</TD></TR><TR><TD CLASS="quote">not sure what spindle you're using but this came off the dss website about the stage 5:
not sure if that helps at all.</TD></TR></TABLE>
I was just about to say something. You have the smaller civic spindles.
Old Oct 3, 2005 | 04:57 AM
FredoSP's Avatar
Default Re: DSS Stage 5 Install Question (White Smoke)
so I gotta get bigger spindles, **** man, maybe b.c the older stage 5's fit. These are the new stage 5's ...
I will call Frank and report back. I appreciate the help guys
FredoSP
Oct 3, 2005 08:11 AM
teler86
Sep 9, 2005 09:55 AM
TurboLude97
Sep 29, 2003 06:48 PM
Blown90hatcH
Dec 20, 2002 06:40 PM
