Injector Resistor Wiring Question
Old Oct 2, 2005 | 10:26 AM
Dunc's Avatar
BCICAN
Default Injector Resistor Wiring Question
This is reference to the write up that is found here: https://honda-tech.com/zerothread?id=517274
Question:
1.) I measure continuity to figure out which four wires go to the injectors. Then that means that the other 4 wires that are not for the injector signals will be the ones that are soldered to the red wire on the resistor box right?
2.) So then where do I solder the black wires on the resistor box? Do I "T" them into the injector signal wires? Use the above picture for reference.
Old Oct 2, 2005 | 11:25 AM
Timmay's Avatar
Default Re: Injector Resistor Wiring Question (Dunc)
ok the red wire from the resistor box goes to the grey plug you hook it to the 4 yellow black wire that went to the injectors
then the 4 yellow black hook to the 4 black wires on the box
so basicly you are putting the resistor box inline with the 4 yellow black wires
hope i said that right
Old Oct 2, 2005 | 11:35 AM
Timmay's Avatar
ok this is the worst pic evar but it was quick
Old Oct 2, 2005 | 11:40 AM
Dunc's Avatar
BCICAN
Default Re: Injector Resistor Wiring Question (Timmay)
OOOHHH I think I got it. I had to read that like 2-3 times for it to sink in haha. Basically it looks like there are 8 wires in total on that particular distribution block. I am only going to be dealing with 4 of them. The red is soldered to all four yellow/black that are coming out of the grey distribution block. Then I solder the black resistor box wires to the other end (since I cut the yellow/black wires) of the wires coming from the injectors. Thanks man...your comment of "so basicly you are putting the resistor box inline" helped me understand.
Old Oct 2, 2005 | 11:41 AM
Dunc's Avatar
BCICAN
EDIT: haha you posted that picture as I was writing the reply. Thats just what I thought. Thanks again!
Time to go put some Precision 1000's on the car Tuning is tomorrow so this could be fun haha
Old Oct 2, 2005 | 11:47 AM
Timmay's Avatar
yea i couldnt write it how i wanted to so i made that lame *** pic
Old Oct 2, 2005 | 12:08 PM
Dunc's Avatar
BCICAN
so I am measuring continuity right now and I am getting readings from more than one hole on the distribution block when I keep the injector the same. Like I mean I am measuring injector #2 to start with and I am getting readings in more than one hole on the grey connector. Is this normal?
Old Oct 2, 2005 | 12:11 PM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">so I am measuring continuity right now and I am getting readings from more than one hole on the distribution block when I keep the injector the same. Like I mean I am measuring injector #2 to start with and I am getting readings in more than one hole on the grey connector. Is this normal?</TD></TR></TABLE>
hmm no, did you take the plug and little white plastic piece out of the grey plug???
Old Oct 2, 2005 | 12:14 PM
Dunc's Avatar
BCICAN
i took the plug out...I'm assuming I need to remove the white piece as well before measuring?
Old Oct 2, 2005 | 12:19 PM
Timmay's Avatar
yes i would make sure you only touching 1 lead, all 4 wires are in a square, well on my car anyway
Old Oct 2, 2005 | 12:21 PM
Dunc's Avatar
BCICAN
I'll go try to remove the white piece then....most likely I'll be back in 5 minutes hahaha
Old Oct 2, 2005 | 12:31 PM
Dunc's Avatar
BCICAN
Going from left to right and starting on the top row:
15,85,0,85
85,0,85,39
Those are the measurement I am getting. I am holding one probe on injector clip number #2 and thats a constant. I then touch each pin on the picture above and thats what I got. I have not touched the injector clips on the other ones yet. So I'm assuming that the ones that are giving me 85 are my injector wires?
Modified by Dunc at 4:50 PM 10/2/2005
Old Oct 2, 2005 | 12:49 PM
Timmay's Avatar
i dont know what #'s you are getting, just look for continuity
my multi meter has a buzzer so i just touch 1 wire on the black/yellow on the injector and the other in the grey plug and start touching wires untill it beeps and that is your wire
so start with #1 and find it and cut it, then move to #2 find it then cut, etc...
that make sense?
Old Oct 2, 2005 | 12:51 PM
Dunc's Avatar
BCICAN
I see....I was measuring in ohms. I was putting the multimeter on 200K
I understand what you are saying completely...I'm just confused as to why I am getting readings when I touch several different pins when I hold the probe on one injector clip and don't move it
Modified by Dunc at 5:43 PM 10/2/2005
Old Oct 2, 2005 | 02:12 PM
Timmay's Avatar
yea you just need to check for continuity
it should on beep for 1 wire, make sureyou take that white clip out so you are getting a good connection on each wire
d15bfi
Sep 28, 2008 10:58 AM
markgo
Nov 8, 2006 11:39 AM
DOHClessEF-9
Feb 5, 2005 04:35 PM
shivern
Nov 28, 2004 08:51 PM
Happyman
Aug 26, 2003 09:08 PM
