ignition for nitrous
Old Oct 5, 2005 | 07:36 PM
doublejz's Avatar
Default ignition for nitrous
Ok so I came to my senses and decided not to boost my 11ish:1 b16. Instead I am going to spray it. What ignition setup do you guys recommend?
I am thinking.
MSD Digital-6 Plus
Blaster 2 Coil or SS Coil
Modified by doublejz at 3:00 PM 10/6/2005
Old Oct 6, 2005 | 05:40 AM
doublejz's Avatar
Default Re: ignition for nitrous (doublejz)
bump
Old Oct 6, 2005 | 11:00 AM
doublejz's Avatar
alrighty then.... thanks
Old Oct 6, 2005 | 02:39 PM
JSPECSIR's Avatar
Ive got an msd 6al box, ss blaster coil, cap, wires, and a msd start/retard box. the retard box works as soon as the n2o solenoid opens. works great.
Old Oct 6, 2005 | 03:11 PM
doublejz's Avatar
Default Re: (5THGENSI)
with the MSD dig 6 Plus I won't need the retard box right? Also, people are always saying dont use no2 if you mis-shift your done.... If your using the the solenoid that only sprays when WOT and you shift correctly (heal to toe), you shouldnt be WOT if you miss a gear, unless your slamming gears/power shifting (screwing your synchros) not letting go of the gas.... correct me if I'm wrong
Old Oct 6, 2005 | 05:18 PM
JSPECSIR's Avatar
you can also put a msd rpm switch on it to cut it off at a certain rpm. then it will stop spraying just before redline. if you miss shift your still ok
Old Oct 6, 2005 | 06:42 PM
six7one's Avatar
also check NX maximizer II it's a RPM based and u can control the amount of n2o. Like say u want a 25shot at 1st gear from 4500 to 4500 in 2nd gear and 50 shot at 4600 in 2nd gear to 4000 in 3rd and 4100 to redline the full shot
EH6TunerDaniel
Texas -OK -LA (Sales)
May 1, 2009 04:41 AM
ricekiller1
Jul 8, 2006 01:05 PM
GSR4U2NV
May 12, 2006 05:49 AM
Jared
Nov 3, 2002 07:09 PM
