which turbo to choose for 350-400HP B16A2
hello everybody.
so i wanna hit the 400hp line with the b16a2 im rebuilding.
im looking for a nice hard powerband from 3000rpm and up. what turbo would you reccomand?
here is the setup:
wisco 10.4:1 pistons (stock CR according to Haynes) should i change the CR?
eagle rods
stock sleevs
polished stock IM.
uberdata and DSM 450's.
new oem gaskets and bearings.
i havent decided yet if i want gsr or ctr cams.
TIA
here is the setup:
eagle rods
stock sleevs
polished stock IM.
TIA
Re: which turbo to choose for 350-400HP B16A2 (RACEPAK)
garret t3/to4e 50 trim....
if you want great response go .48 a/r
a little lag go .63 a/r
Check out http://www.phoenixturbo.com
they'll take car of ya'
Good luck
Good luck
Re: which turbo to choose for 350-400HP B16A2 (Maveric)
you are going to need bigger injectors for 400 wheel.
And I would lower compression to ~9:1 and run a .63ar t3/t4 like Maveric said.
