got the ol' bitch tunned... now for the idol... (uberdata)
Old Oct 3, 2005 | 06:02 AM
turboH22Aakkord's Avatar
Default got the ol' bitch tunned... now for the idol... (uberdata)
well i finally got my 550's and put them in yesterday and started tunning right away... this is my first tunning attempt and it actually went pritty good... the AFR's are really good and even decent in boost the car is pritty much ruffly tunned (i dont have any datalogging) my only problem is... the car doesnt seem to idol very well... and when i pull the clutch in and coast (like at a stop sign) the car shuts off... i have my fuel modifiers set at like 5 points higher then the "sugested" which seemed to help a little... and when the car is idoling it shows lean on the wideband (but the stock ecu does the same thing)... should i just try richening it up a little? im just looking for some tips guys.. thanks...
setup
jdm h22a
venom fuel pump
aem rail and FPR
3" DP back
Old Oct 3, 2005 | 07:04 AM
Default Re: got the ol' bitch tunned... now for the idol... (turboH22Aakkord)
ttt
Old Oct 3, 2005 | 07:27 AM
Bailhatch's Avatar
Sometimes you need to run big injectors rich in order to get a smooth idle. Just keep adding fuel until it feels good. somewhere between 13-14.3 should work well for you.
Old Oct 3, 2005 | 07:51 AM
Default Re: got the ol' bitch tunned... now for the idol... (Bailhatch)
so richen the **** out of the higher vacc colums? thanks for the advice adam
Old Oct 3, 2005 | 09:39 AM
ttt men...
Old Oct 3, 2005 | 09:43 AM
LST2's Avatar
My 750's have a lean misfire with anything over 13.5 so it does like to idle rich. However, I have it tunned at 15.5 to save on gass. I dont mind the missfire. You can also try to advance the timming a few degrees and increase your idle RPM. I have my idle timming at 24* and the idle at 1,000 RPM. If I have the AF at 13.5 it idles like stock.
Old Oct 3, 2005 | 09:49 AM
Tactic$'s Avatar
i dont mind the misfire either.... the ricer in me kinda likes it...... tuned at 15.3 a/f for idle
Old Oct 3, 2005 | 10:14 AM
Default Re: (Tactic$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">i dont mind the misfire either.... the ricer in me kinda likes it...... tuned at 15.3 a/f for idle</TD></TR></TABLE>
thanks for the responses guys... so for the idle pulling deep vaccum ( over 20 in/hg) you guys are seeing 15:1 on your wide band? ... ill tune that **** right up when i get home.. thanks guys...
Old Oct 3, 2005 | 10:26 AM
boosted k20's Avatar
did u set the fuel cut to 14 (stock injectors) with 3-bar u need ot set it to 8
Old Oct 3, 2005 | 10:29 AM
Default Re: got the ol' bitch tunned... now for the idol... (boosted k20)
im using uber 1.6 (dont ask me why haha) but where the hell is the fuel cut? (and im running the stock map)
Old Oct 3, 2005 | 10:42 AM
LST2's Avatar
If you are on stock map don't worry about the fuel cut. Just keep it where it is. If you are stalling and your AF is OK it is probably your idle speed...
Old Oct 3, 2005 | 11:04 AM
Default Re: got the ol' bitch tunned... now for the idol... (LST2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LST2 &raquo;</TD></TR><TR><TD CLASS="quote">If you are on stock map don't worry about the fuel cut. Just keep it where it is. If you are stalling and your AF is OK it is probably your idle speed... </TD></TR></TABLE>
kool man.. thanks.. im gona tune the **** out of that bitch when i get home haha... (since im not datalogging and just kinda going by eye... are there any tips or precautions i should be taking? ) thanks guys
Old Oct 3, 2005 | 11:26 AM
LST2's Avatar
don't worry too much about tunning vaccume.. you can't really cause much damage in light load.. really only tuning for MPG and throttle response. Start rich in boost and start maybe with 1*/psi retard or a step retard. Tune your AF in boost (say 11.5-12). I would not mess with timing much until you hit the dyno... just keep a standard retard.
SilverEK96
May 17, 2013 04:09 PM
2000siturboR
Jun 2, 2008 08:09 PM
Frost7177
Mar 25, 2007 08:27 AM
busakiller
Aug 8, 2004 08:02 PM
TeamCracka
31
May 7, 2004 05:36 PM
