Dejon Tool Boost Controller
Old Oct 2, 2005 | 06:22 PM
Dunc's Avatar
BCICAN
Default Dejon Tool Boost Controller
For anyone that is familar with the Dejon Tool manual boost controller. I have a Tial 38mm with a 7psi spring in there right now. Is it possible for the mbc to turn the boost up to like 18-20psi without buying a bigger wastegate spring?
Old Oct 3, 2005 | 12:05 PM
JDM EJ1 95's Avatar
arent they a dsm company...
i have a buscher racing MBC on my car and it holds at 13 perfectly if that helps any
Old Oct 3, 2005 | 12:43 PM
nickromeo's Avatar
Default Re: Dejon Tool Boost Controller (Dunc)
GOT FOR IT MAN THEY ARE JUST AS GOOD AS OTHER BALL+SPRING MBCS!!!!
Old Oct 3, 2005 | 12:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
we use them for dsm stuff, i didnt look at the tool but if it is the ball and spring that i am thinking of you should be fine.
Old Oct 3, 2005 | 06:00 PM
Dunc's Avatar
BCICAN
Default Re: Dejon Tool Boost Controller (boostedcivicsir)
Yes they are typically found on DSM's and what not. It's not that I am wondering if I should buy it or not....I already have it. I also have the 7psi spring installed in the Tial 38mm. I was just wondering if that MBC could take it to 18-20psi since the wastegate spring is only for 7psi. It is a ball & spring style MBC also. I just recall hearing that you can only double the spring rate..... i.e. take the 7psi spring up to 14psi. Buuut I don't know how much truth is involved in that.
powerdbygarrett
Jul 3, 2008 01:50 PM
TurboCoop
May 19, 2004 12:21 PM
gdrum
Feb 24, 2004 01:55 PM
b18bvudoo
May 30, 2002 12:45 AM
Turbo_Teg
Jan 14, 2002 07:35 PM
