compression change
Old Oct 2, 2005 | 10:42 AM
b18cEF9's Avatar
Default compression change
i was wondering if my compression would change if i was using a b18c head on my b16 block, im getting wiseco 9.0-1 .020 over. just curiouus if it would effect the compression ratio
and another thing, would the b16a2 be the same kinda pistons for the first gen b16? ive looked but no one has pistons for the first gen b16. sorry for the dumb questions
Old Oct 2, 2005 | 10:53 AM
1.8turbolsvtec's Avatar
Default Re: compression change (b18cEF9)
this will help http://www.ff-squad.com/technet/cr-calculator.htm
Old Oct 2, 2005 | 11:35 AM
b18cEF9's Avatar
Default Re: compression change (1.8turbolsvtec)
doesnt help too much, or im just confused. can only pick what kinda of piston, and not what the compressions of the piston is gunna be.
b18c head, b16 block, 3 layer head gasket, and 81.5mm bore comes out to be 9.29 CR
thast without picking what kind of piston......
when i pick the pr3 piston, with the same head,block,headgasket,bore i get a 15.0 CR
om looking to get a 9.0-1 CR
sombody wanna help me out with this stuff
Old Oct 2, 2005 | 11:41 AM
b18cEF9's Avatar
aha, got it i beleive,
b16 block, gsr head, 3 layer headgasket, 81.5mm bore, p72 pistons with the AO under them
CR = 9.2
now can someone tell me what the AO stands for under the p72 pistons
one set says A0, and the other set says 00
Old Oct 2, 2005 | 06:17 PM
b18cEF9's Avatar
cmon people.little more opinions or advice
Old Oct 3, 2005 | 04:08 AM
yes 9.2cr http://www.ff-squad.com/technet/cr-calculator.htm
Old Oct 3, 2005 | 07:24 PM
b18cEF9's Avatar
yes but whast the difference in both of the p72's?
also, it said i would get about 8.8 CR with pr4 pistons...didnt know they would work in a b16 block
sorry this is the first time building a motor, trying to understand the compression changes...
Old Oct 8, 2005 | 11:40 PM
look at youir first ?
oerski
Oct 25, 2006 07:28 PM
black99x
Aug 13, 2006 01:23 PM
7rrivera7
Oct 20, 2003 04:55 PM
SolidSpruce
Aug 27, 2003 05:35 AM
Nextelbuddy
Jun 20, 2003 11:14 AM
