which block
Old Oct 2, 2005 | 07:49 PM
datnigabluberry's Avatar
Default which block
i just bought a 93 del sol with a b16 im gonna turbo it, but i want to get around 350- 400 wheel horsepower. so should i keep my b16a block, get an ls block , or get a gsr block. what will be more relieable
Old Oct 2, 2005 | 08:06 PM
LVB18Civic's Avatar
Default Re: which block (datnigabluberry)
I would say keep the b16. If you are shooting for 350-400hp you will need to do internals to whatever engine you choose, so might as well use the one you got.
Old Oct 3, 2005 | 08:42 AM
Default Re: which block (LVB18Civic)
yea i was thinkin that but i might have to drive the car through winter so i was gonna buy a block to build then throw it in when its built so i dont have any down time
Old Oct 3, 2005 | 05:03 PM
LVB18Civic's Avatar
well then in that case just buy another b16. they're cheap.
Old Oct 3, 2005 | 06:02 PM
turboEGhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic &raquo;</TD></TR><TR><TD CLASS="quote">well then in that case just buy another b16. they're cheap.</TD></TR></TABLE>
And an LS block isn't? He's gonna replace the pistons and rods anyways, so he might as well get some good torque out of it.
Old Oct 3, 2005 | 06:12 PM
Importordomestic's Avatar
Default Re: which block (turboEGhatch)
well im my opinion, i would use A VTEC block prolly the gsr. but i would put a LS crank and use GSR equivilant Eagle rods. and have custom pistons made wit hthe wrist pin move up so the piston wont hit the head.
with this senario, you gett 100% durability of your vtec oiling system (for vtec engagement) and you get the low end tq of a ls with a decent rod to stroke ratio.
Oh and you also get to keep the blockgirdle that normally comes in the GSR (stiffins the block for high rpm.)
also remember the kinda unwritten rule (more displacement = more power.)
Old Oct 3, 2005 | 06:52 PM
Default Re: which block (Importordomestic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importordomestic &raquo;</TD></TR><TR><TD CLASS="quote">well im my opinion, i would use A VTEC block prolly the gsr. but i would put a LS crank and use GSR equivilant Eagle rods. and have custom pistons made wit hthe wrist pin move up so the piston wont hit the head.
A 1.54:1 rod stroke ratio is hardly different from a 1.56:1 rod/stroke ratio. Having custom pistons made for a 350 WHP motor when he's on a budget is nothing short of retarded. Courtney Green runs a stock length LS rod with an LS crank in his LS/VTEC that's made over 800 WHP on gasoline, but what the hell would he know anyways.
boostedb16EG
17
Oct 6, 2012 07:48 AM
ys1civicsi
Feb 25, 2007 09:23 AM
EikoU
Dec 4, 2005 07:51 PM
JDM96SpecCTR
Aug 25, 2005 04:43 AM
LSEGHATCH
Mar 2, 2005 02:46 PM
