Smoke from Engine Bay
Old Oct 4, 2005 | 07:21 AM
drecivic's Avatar
Default Smoke from Engine Bay
Yeah I got a 88 crx si with a b16a turboed its been smoking out of the valve cover, not the valve cover itself but , damn I forgot the name of the thing its that lil Hose that comes from the valve cover, I would drive it down to a shop and see what the problem is (if there is one)but I wanna see if I should even be driving it, The car starts right up though, I know I dont know I sound like a noob or whatever but help me out, cars boostin about 9 psi
Old Oct 4, 2005 | 07:22 AM
SOHC_MShue's Avatar
Default Re: Smoke from Engine Bay (drecivic)
Your ringlands are more than likely gone. Time for a rebuild.
Old Oct 4, 2005 | 07:28 AM
drecivic's Avatar
thanks, but could it be that the car hasnt been ran in a long time too ? , because the car hasnt been started in about 7 months, started it up last night
Old Oct 4, 2005 | 08:13 AM
nonvtecD's Avatar
more than likely it's your rings, do a compression test.
Old Oct 4, 2005 | 08:15 AM
1boostedcivic's Avatar
Default Re: Smoke from Engine Bay (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">more than likely it's your rings, do a compression test.</TD></TR></TABLE>
Old Oct 4, 2005 | 08:41 AM
11psiTurboSI's Avatar
Default Re: Smoke from Engine Bay (1boostedcivic)
Same thing happen to me, ended up being that I cracked a couple ringlands.
Old Oct 4, 2005 | 08:50 AM
AP-Signworks1's Avatar
Yeah, it's most likely your rings, so compression test it. Same thing happened to me on the dyno, car hadn't run in 4 months, started it up, took it to the dyno and noticed that there was a little bit of smoke coming out of the breather. Figured it was from sitting so long, made a run, smoke started pouring out of the breather along with some oil spray.
I would avoid driving it if possible. I kept driving mine for about 3 more months while I waited on a new motor, but I never hit boost. I just had to drive it to get it to events and shows, car started and drove perfectly, but the motor definitely wasn't healthy.
Old Oct 4, 2005 | 09:56 AM
drecivic's Avatar
Thanks alot guys, really appreciated
vxturbociv
Jul 23, 2006 06:27 PM
Ls-Turbo
Dec 11, 2005 10:30 AM
Ls-Turbo
Dec 11, 2005 10:28 AM
xxthabest1xx
May 13, 2004 07:01 PM
ItzTw
Dec 14, 2003 07:10 AM
