Eagle rod
Old Oct 2, 2005 | 10:26 AM
B20bTurbo's Avatar
Default Eagle rod
The torque spec on the instructions are confusing me a bit. When you use a 3/8 socket to tighten them up is it 43 ft lbs? Because it saids bolt head 7/16 for the same one. Basically my question is how do you know if you have the newer 3/8 bolts? From using a 3/8 socket to tighten it up, or is it measured by the actual bolt itself at the bottom?
Old Oct 2, 2005 | 03:33 PM
B20bTurbo's Avatar
Default Re: Eagle rod (B20bTurbo)
anyone?
Old Oct 2, 2005 | 03:34 PM
Dragline's Avatar
Bolt it self.
Old Oct 2, 2005 | 04:11 PM
earl's Avatar
If you use a 7/16" socket, you have the 3/8" bolt....torque to 43
If you use a 3/8" socket, you have a 5/16" bolt...torque to 28
Old Oct 2, 2005 | 04:21 PM
rpm11's Avatar
Default Re: Eagle rod (earl)
I'm stalking you Earl, haha.
Are the 5/16 bolts still available/commonly used?
Ron
Old Oct 2, 2005 | 06:28 PM
B20bTurbo's Avatar
Default Re: Eagle rod (rpm11)
Thanks earl thats exactly what I needed. The only problem now is that when checking for clearances I torqued one rod to 43 lbs, you think I may have damaged the bolt? It did feel weird tightening it up, which is why I stopped on that rod. Im pissed now, I though I had the newer one's. Im wondering If I should buy a new set of rods. Im looking for 400whp and would hate for a rod to go threw my Bensons sleeves. I bought these rods about 2 years ago( I know, I took a long break) and thought there were the 3/8 till know. Anyone using these rod bolts with good success?
Old Oct 2, 2005 | 06:39 PM
rpm11's Avatar
Bolt specs are based on 75% of yield, so you have certainly exceeded
yield torque.
It would be interesting to measure the length of the suspect bolts and compare that to the other bolts.
Old Oct 2, 2005 | 06:49 PM
NJIN BUILDR's Avatar
Give Eagle a call on Monday and get some new bolts.The 5/16" bolts will do the job if they are installed right the first time.Over-torquing and stretching the bolts is not the way to get them to survive.
Glenn
Old Oct 3, 2005 | 09:46 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpm11 &raquo;</TD></TR><TR><TD CLASS="quote">I'm stalking you Earl, haha.
Ron</TD></TR></TABLE>All Eagles sold from AUTHORIZED dealers now have the 3/8" diameter bolts. What you buy off of e-bay or extra cheap web sites could be anything. Be careful when the price is too cheap.
Old Oct 3, 2005 | 11:38 AM
redzcstandardhatch's Avatar
something different
SHOOT...i just put my eagle rods in my d16...i have the newer bolts..but i only torqued to 28.
should i drop the pan and retorque them?
crap. .
edit...i just called earl, and he told me to drop the pan.
thanks earl.
Old Oct 3, 2005 | 11:56 AM
Benjithx's Avatar
Default Re: (redzcstandardhatch)
yes
StolenTeg
May 25, 2010 11:27 AM
hybrid2007
20
Mar 27, 2008 01:56 PM
kidd_drastic
Jan 28, 2006 10:04 AM
PM-Performance
Feb 20, 2004 04:08 AM
blufke
Feb 19, 2004 08:05 AM
