half radiator doesnt fit!
Old Oct 1, 2005 | 05:05 PM
ham's Avatar
ham
Default half radiator doesnt fit!
I only have 12 inches between my headlight and wastegate! a half radiator doesnt even come close to fitting! I tried tilting it back and tucking it somewhat behind the headlight and it overheated like a mother (knew it was going to happen)
i dont want to pay $350+ for a custom radiator, do i have any other options?
its a crx gsr SC61
EDIT!: problem fixed! see page 2!
Modified by ham at 2:01 PM 10/9/2005
Old Oct 1, 2005 | 05:30 PM
primeredbeast's Avatar
Default Re: half radiator doesnt fit! (ham)
i had to get a aftermarket crossmember that has the lower mount so the radiator will fit correctly place racing or jim fab will all work
Old Oct 1, 2005 | 05:49 PM
Adriano's Avatar
Default Re: half radiator doesnt fit! (primeredbeast)
Your best bet would be a custom or go to the junk yard and try to find something that fits.
Adriano
Old Oct 1, 2005 | 06:15 PM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">i had to get a aftermarket crossmember that has the lower mount so the radiator will fit correctly place racing or jim fab will all work </TD></TR></TABLE>
i have a z10 crossmember, but height is not the issue.
Old Oct 1, 2005 | 06:28 PM
bluemax189's Avatar
um....what about relocating the wastegate????
Old Oct 1, 2005 | 07:41 PM
ham's Avatar
ham
Default Re: half radiator doesnt fit! (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">um....what about relocating the wastegate????</TD></TR></TABLE>
but my beautiful manifold
Old Oct 1, 2005 | 07:54 PM
Ls1 FD3s's Avatar
WTF you doing running a stock intake mani?&gt;
PS b-series in a EF chassis just sucks...
Sorry.
Old Oct 1, 2005 | 08:02 PM
mstolars's Avatar
Why not move the wastegate to the top of the mani somehow, looks possible, might be the easiest way without getting a custom radiator.
Old Oct 1, 2005 | 09:16 PM
beepy's Avatar
The question is, was this manifold made for this chassis, and if so, what sort of radiator is it designed for?
I see two choices. Spend $400 on a custom radiator that will fit, or spend $400 for a manifold that will fit.
Old Oct 1, 2005 | 09:26 PM
ham's Avatar
ham
Default Re: half radiator doesnt fit! (Ls1 FD3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">WTF you doing running a stock intake mani?&gt;
Sorry. </TD></TR></TABLE>
what are you talking about? stock intake mani with open plenum is very good for forced induction.
Old Oct 1, 2005 | 09:52 PM
mrbsponge's Avatar
put an elbow on the wastegate, from the manifold side, and clock it up a bit, had to do this on a friends.
Old Oct 1, 2005 | 10:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (mrbsponge)
yea, wg placement is to blame for the rad. not fitting
Old Oct 2, 2005 | 12:01 AM
ICeDoUt's Avatar
Yea wtf are u talking about? B series is fine in ef chassis, its when u turbo it starts getting cramped.
If u don't like it then get an eg, simple as that, otherwise enjoy the lightweight fun
Old Oct 2, 2005 | 12:11 AM
LoSt is BlaCk's Avatar
Default Re: half radiator doesnt fit! (ICeDoUt)
slap an elbow on the mani for the wastegate...
Old Oct 2, 2005 | 07:28 AM
ham's Avatar
ham
Default Re: half radiator doesnt fit! (LoSt is BlaCk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoSt is BlaCk &raquo;</TD></TR><TR><TD CLASS="quote">slap an elbow on the mani for the wastegate...</TD></TR></TABLE>
i was thinkin that too, ill give that a shot
Old Oct 2, 2005 | 09:34 AM
turbodan4's Avatar
full race makes a half size radiator for the crx that should work its about 12x12 i bought one for my integra to fit with the peak boost manifold and wastegate. I made it fit and havent had anything close to an over heating problem yet. It is pricey($300) but it works nice.
Old Oct 2, 2005 | 09:48 AM
project dc2's Avatar
you can hit up i think passwordJDM has a cheap crossmember. its a factory replacement sort of thing with better clearances for bigger downpipes. and it also has provisions for half core radiators. however im unsure of that clearance between the WG and radiator. even on an EG i think its a shitty placement and needs revising.
Old Oct 8, 2005 | 04:31 PM
ham's Avatar
ham
ordered a 90 degree elbow from crpturbo.com and a full race 1/2 radiator for a crx!!!
Old Oct 8, 2005 | 06:33 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">ordered a 90 degree elbow from crpturbo.com and a full race 1/2 radiator for a crx!!!</TD></TR></TABLE> post up some more pics because i have ef hatch and I'm going to run into some of the problems and maybe i can use your thread for some kind of reference.thanks and good luck
Old Oct 8, 2005 | 06:38 PM
Si Shane's Avatar
have you tried sticking it in like this?
Old Oct 8, 2005 | 06:50 PM
AbitAvenger's Avatar
what size dp is that ^??
Old Oct 8, 2005 | 07:01 PM
linkmustang's Avatar
why two blowoffs
Old Oct 8, 2005 | 07:06 PM
JDM00SI's Avatar
Default Re: half radiator doesnt fit! (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">have you tried sticking it in like this?
^^^SICK^^^^..... do that or use a elbow, a elbow costs nothing at all, under 50 bucks.....
Old Oct 8, 2005 | 07:45 PM
ham's Avatar
ham
Default Re: half radiator doesnt fit! (JDM00SI)
i dont want to put my radiator like that because it looks like ****!
Old Oct 8, 2005 | 08:58 PM
Justin Olson's Avatar
I think the slanted radiator looks slick. If you dont want to do that tho, have someone modify your manifold so the wastegate doesn't go off at such an angle. Or buy a wastegate elbow.
Modified by Justin Olson at 10:08 PM 10/8/2005
