Polish/Balance Crank....
Old Oct 3, 2005 | 01:08 PM
B18Sleeper's Avatar
Default Polish/Balance Crank....
Should I polish and balance my gsr crank? if so where would be the best place to send it off too? thanks
Old Oct 3, 2005 | 02:38 PM
Muckman's Avatar
Moderator in Chief
Default Re: Polish/Balance Crank.... (RedlineKustomz)
You can find a local shop that does engine work, thats pretty standard stuff. It honestly doesnt need it unless you've damaged the journels or unless you want to rev higher than stock.
Old Oct 3, 2005 | 02:53 PM
B18Sleeper's Avatar
Default Re: Polish/Balance Crank.... (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">You can find a local shop that does engine work, thats pretty standard stuff. It honestly doesnt need it unless you've damaged the journels or unless you want to rev higher than stock.</TD></TR></TABLE>
Well I dont wanna rev higher but should i just take it to a local shop and let them look and see if its damaged or needs it? Thanks
Old Oct 3, 2005 | 04:10 PM
Muckman's Avatar
Moderator in Chief
It'll be fine unless you spun a main/rod bearing or unless there are any scratches on the journels that are fingernail worthy.
Old Oct 3, 2005 | 06:53 PM
B18Sleeper's Avatar
Cool well when I get my motor apart I will look and see, cause I dont know the real condition of the motor I have. I bought it off a site where they say "came from a running car" so who knows. We'll see thanks alot
Old Oct 6, 2005 | 02:16 AM
D@nnY's Avatar
I sent my crank to benson and it came out great... he balances it and polishes it for 150$ just pm earl....if the crank is nto balanced correctly it can really screw up your mtoor high rpm
Old Oct 6, 2005 | 03:15 AM
B18Sleeper's Avatar
Default Re: Polish/Balance Crank.... (D@nnY)
cool I guess since it aint an arm and a leg it should just do it to make sure. 150 aint that bad for something that can really help me.
Old Oct 6, 2005 | 04:06 AM
D@nnY's Avatar
you wont regret it....
Old Oct 6, 2005 | 04:27 AM
B18Sleeper's Avatar
Default Re: (D@nnY)
well i hope it lol.
leroyb
Apr 17, 2009 10:14 PM
. a d a m
10
Aug 1, 2007 04:42 PM
rasta420
Apr 18, 2007 12:05 PM
mrDFWmechanic
May 9, 2005 11:28 AM
RATEDR
Mar 13, 2002 09:45 AM
