Datalogging problem?
Old Oct 4, 2005 | 05:44 PM
JDM EJ1 95's Avatar
Default Datalogging problem?
I tried to datalog today and i was having a problem....
it connects just fine to the ecu and shows the gauges and all the sensor values...
but when i hit record.. the record just blinks red and goes back to yellow.... it will only record like .0001 of a second at a time.. hahah
so just wondering if anyone has had this problem before.... if not.. thats ok its not a big deal.
Old Oct 4, 2005 | 06:26 PM
JDM EJ1 95's Avatar
up... anyone?
Old Oct 4, 2005 | 10:56 PM
mtber's Avatar
Default Re: (JDM EJ1 95)
I am guessing you are trying to log using a obd1 honda ecu ?
Check to see if you need to remove j12 with the datalogging software you are using etc...
Old Oct 4, 2005 | 11:26 PM
JDM EJ1 95's Avatar
ITs hondata....
Old Oct 5, 2005 | 10:26 AM
JDM EJ1 95's Avatar
uppp
Old Oct 6, 2005 | 12:12 PM
JDM EJ1 95's Avatar
bump... itll connect fine and it shows everything working...
but when i hit RECORD it records for like a split second then stops... so i cant record anything
Luserkid
Nov 17, 2012 05:21 PM
2000EM1will
Engine Management and Tuning
May 27, 2011 01:29 PM
EJ1B18c
Oct 22, 2008 07:52 AM
TokuiAutowerks
Dec 13, 2004 07:29 PM
