Eagle Rods ARP Bolts Torque and Angle???
Old Oct 2, 2005 | 03:38 PM
rikawa's Avatar
Default Eagle Rods ARP Bolts Torque and Angle???
Hi All, as i have searched, but didn't find, I'd like to know:
I got a set of H Eagle Rods for my B16a, and i'm going to take the meassurement to get the right OEM bearings. What I'd like to know is, the right torque method:
I Just need to torque to 28lbs and use the moly on the bolts(as the sheet says), or i should use the angle method after torqued.
The ohter question is, is there any problem, if the Moly package, stays opnened for let's say some months, until a get the bearings to build my engine? (That's beucause i live in Brazil and things need some time before get in my hands...
I Need this answer as soons as possible, for know the rights bearings sizes....
Very thanks! And sorry for may bad english.
Old Oct 2, 2005 | 04:05 PM
earl's Avatar
Default Re: Eagle Rods ARP Bolts Torque and Angle??? (rikawa)
Just torque them to 28 lbs using the moly lube and you will be fine. The moly packet can stay open for many months with no affect
If you use ACL bearings you will have no wait time.
Old Oct 2, 2005 | 04:09 PM
rpm11's Avatar
I always use a stretch gauge on rod bolts, the angle method is used
for torque to yield fasteners, which yours are not.
The 28 ft/lbs sounds like a 5/16 bolt, if that's the case I would
send them back for a rod with 3/8 bolts.
Old Oct 2, 2005 | 04:13 PM
earl's Avatar
Default Re: Eagle Rods ARP Bolts Torque and Angle??? (rpm11)
I don't imagine it would be that easy for him since he is in Brazil
Old Oct 2, 2005 | 04:17 PM
rpm11's Avatar
Default Re: Eagle Rods ARP Bolts Torque and Angle??? (earl)
Agreed, but I still would never use a 5/16 bolt in a high revving Honda.
Old Oct 2, 2005 | 04:35 PM
paulzy's Avatar
jsut use the torque given to you from Eagle and a stretch gauge. I think the only rod company to use torque and angle is Oliver
Old Oct 2, 2005 | 04:41 PM
rikawa's Avatar
Hi All! Thanks for the replys!!!
rpm11: The 28 ft/lbs sounds like a 5/16 bolt, if that's the case I would
my rods cames with 3/8" Bolts, and on the sheet(that cames with the rods from eagle) says 28 lbs for the 3/8".
earl: The moly packet can stay open for many months with no affect. If you use ACL bearings you will have no wait time.
Hi earl, as always, saving me.
Thanks!
Old Oct 2, 2005 | 05:05 PM
rpm11's Avatar
All my spec sheets are at my shop but usually the 3/8 bolts take 42-43 ft/lbs.
Please double check your spec sheet.
edit: If you mean you are using a 3/8 12 pt wrench on the bolt head, that is
a 5/16 bolt.
Modified by rpm11 at 2:22 AM 10/3/2005
Old Oct 3, 2005 | 03:14 PM
rikawa's Avatar
Hi, it's me again, they are 3/8" ARP 2000 - 7/16" bolt head - 43 ft lbs.
Very thanks!
SPOOLINmatt
Mar 29, 2010 05:10 AM
andyrew500
Mar 4, 2006 02:53 AM
boostedsolv10eater
Feb 16, 2004 10:38 PM
Nextelbuddy
Feb 12, 2004 12:39 PM
senpai
Jun 5, 2003 09:34 AM
