jrsc stock injectors
will i be okay on my stock injectors with this:
gsr motor
jrsc at 10psi
JR 5:1 fmu
walbro 255lph fuel pump
base pressure at 40psi
i'm thinking that would be what.. roughly 90psi at WOT ????
gsr motor
jrsc at 10psi
JR 5:1 fmu
Re: jrsc stock injectors (hondaeg8)
That is the same setup I used to bust the ring lands off of my original B16 pistons.
Why don't you do the other setup you were talking about with the bigger injectors and lower fuel pressure?
Re: jrsc stock injectors (rmcdaniels)
cause i think the injectors i got with the kit came off a buick
weren't you running a higher base fuel pressure though? i thought you were running like 5x psi at idle with hose on??
DeDonDeRosa
12-17-2002 05:24 AM
DeDonDeRosa
12-16-2002 11:19 AM
