which d-series for boost?
Old Oct 3, 2005 | 02:20 PM
92CHB's Avatar
Default which d-series for boost?
Okay well my d15b7 **** the bed with my budget turbo setup. Now i can get a jdm d15b vtec(130 hp) for about $500 with about 45k or i could get a obd1 DOHC ZC non-vtec(130hp) for about $650 from nippon-motors. I am leaning toward the ZC cuz of the DOHC and i think its a stronger motor but i am not too sure. I need peoples opinion's or expierences with these motors for which one is better for boost. Thanks!
Old Oct 3, 2005 | 02:40 PM
nonvtecD's Avatar
ZC is defnitely stronger but you can get a z6 in the states for a lot cheaper than $650. Seeing as a D is a D, it doesn't much matter.
Old Oct 4, 2005 | 06:47 AM
92CHB's Avatar
Anyone else?
Old Oct 4, 2005 | 08:03 AM
doubleA's Avatar
Default Re: (92CHB)
I agree with nonvtecD. I would go for the dual cam zc if your going to spend $500+ otherwise I would try and find a z6/y8 for $300 or less. Or I stick with the A6 because I can usually find them for under a hundred bucks
Old Oct 4, 2005 | 08:28 AM
1995Civic's Avatar
z6 fo sho. Unless your up for spending the 500 or so, then go with the ZC. Either way, its alllll up to you.
Old Oct 4, 2005 | 09:41 AM
redzcstandardhatch's Avatar
something different
i LOVE d16a6's . nothing wrong with them...
dohc zc's arent any "stronger" but the head flows better. the bottom ends are virtually identical, just diff. pistons.
Old Oct 4, 2005 | 09:54 AM
PHILLIPDEEZ's Avatar
Default Re: which d-series for boost? (92CHB)
i boosted my Z6 and i love it. z6/y8 have a way bigger aftermarket. Also if something breaks its always cheap to fix
Old Oct 4, 2005 | 10:45 AM
92CHB's Avatar
Default Re: which d-series for boost? (PHILLIPDEEZ)
I'll agree with you there but as for parts for the JDM DOHC ZC; couldn't i use the parts from a 88-89 teg that has an A6, meaning gaskets and such.
Old Oct 5, 2005 | 07:01 AM
nonvtecD's Avatar
Default Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">i LOVE d16a6's . nothing wrong with them...
dohc zc's arent any "stronger" but the head flows better. the bottom ends are virtually identical, just diff. pistons. </TD></TR></TABLE>
dohc zc's have thicker rods
eggsxr
Jul 14, 2013 10:21 AM
91crxracer
Oct 2, 2005 04:14 PM
vietnameeh
Apr 3, 2005 04:07 AM
USDMMARK
Sep 7, 2003 10:13 AM
B16CivicHB
33
Jan 24, 2002 07:21 AM
