Turbo Tips and information
Old Oct 2, 2005 | 08:25 AM
ludesleep's Avatar
Default Turbo Tips and information
You always start selecting your turbos by choosing the compressor housing that best fit your application. Doing this by using this formula CFM=CID/1,728 x Rpm/2 x VE. (VE is at least 100% so use 1.0 for VE)
CFM required under boost- CFM boosted= CFM unboosted x pressure ratio
Airflow is measured in (lbs/per min) to convert cfm to lb/min, a good rule of thumb for 80%F at sea level is to multiply cfm by 0.07.
Lb/min=cfm boosted x 0.07
Every 1 lb/min of airflow is worth about 10hp so to find the required lb/min for a race-only application, start with the horsepower requirement then divide by 10
Lb/min=hp/10
Old Oct 2, 2005 | 11:06 AM
PRDM's Avatar
Default Re: Turbo Tips and information (ludesleep)
Whats is CID?
And what RPM im guessing Redline?
Its like chinese, I had to read it like 3 times lmao...
Old Oct 2, 2005 | 11:47 AM
planeman01's Avatar
cubic inch displacement
goingtobefast
Jun 26, 2005 10:32 AM
torqueless
Dec 6, 2004 07:31 PM
speedemon
Oct 14, 2004 09:40 PM
flip1199
Oct 15, 2002 02:05 PM
