303 whp Dyno - D16Y7 non VTEC
Hey guys
Dennis tuned this D16Y7 a few days ago. Just thought I would share the results for you boosted D series lovers
D16Y7 block
Eagle rods
Suzuki Vitara pistons (fjt)
OEM honda bearings
OEM honda head gasket
ARP head studs
KMS block guard
D16Y7 head (very mild port/polish)
regrind cam
no cam gear
3" DP
KTeller 3" exhaust
the owner is oxhernandez on here
the first pull was @ 17psi
the second was @ 20 psi
D16Y7 block
Eagle rods
OEM honda bearings
ARP head studs
KMS block guard
regrind cam
no cam gear
3" DP
KTeller 3" exhaust
Re: 303 whp Dyno - D16Y7 non VTEC (tunedbylorange.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemanlan »</TD></TR><TR><TD CLASS="quote">Badass.</TD></TR></TABLE>
x2
x2
Re: (11psiTurboSI)
What turbo?
What manifold?
How does the engine run without a cam gear? LoL.
I think that's the most hp I've seen from a Vitara setup.
What manifold?
Re: (booscivic)
Wee.. i love seeing more good numbers on the vitaras. Assuming all the parts come in... i'll be going upto a t3 60/63 soon... hopefully i tune it into a similar power range.
What was it tuned on? If its crome/TE/uberdata... would u guys mind forwarding the map? I'm slowly accumulating other vitara maps to compare notes.
<--- new to ignition tuning for power (i like fuel tuning )
Re: 303 whp Dyno - D16Y7 non VTEC (LoSt is BlaCk)
well its t3/t4e 60 trim 48ar obx manifold modified by lorange and yes it was on pump gas 93octane.And yes i have crome pro program.
The Boot
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">750cc injectors/ street tunning first</TD></TR></TABLE>
Re: 303 whp Dyno - D16Y7 non VTEC (oxhernandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxhernandez »</TD></TR><TR><TD CLASS="quote">well its t3/t4e 60 trim 48ar obx manifold modified by lorange and yes it was on pump gas 93octane.And yes i have crome pro program.</TD></TR></TABLE>
wow, i got a t3/t04 with a obx mani, on the same motor!!!
you've just gave me a progative to build mine a little before i run to a single cam vtec.
nice number's keep up the good work man.
