CEL code 7. ive read all posts and none are the same as my problem. please help
Old Oct 4, 2005 | 07:22 PM
redturbosi's Avatar
Default CEL code 7. ive read all posts and none are the same as my problem. please help
All right i have the tps set right its at .51 closed and wot its going to 5.1.
my set is a 95 integra gsr with built original motor and obd1 p72. the car has a revhard kit with sc61 and i running hondata s200b. the car is running fineand the only time the cel comes on is when i floor it. i can be in 2nd gear at 3k rpm and floor it and about 2 seconds it will pop on. the only time it comes on is when i floor it. i changed it with another tps so i know it is not the tps. what other things could it possibly be.
i have read every post and none are the same problems. could it possibly that the voltage is getting to high at wot. 5.1 is wot. please help me or give me any tips. car is not driving strange just slower with the cel on. doesnt idle funny but it is idleing at about 1k. would adjusting the idle help possibly. i think ive already tried that though. thanks in advance for any advice.
Old Oct 4, 2005 | 07:56 PM
redturbosi's Avatar
someone said they set theres in between .38 and .5 closed and 4.3-4.8 wot. would this help
Old Oct 4, 2005 | 10:38 PM
rice_classic's Avatar
Default Re: (redturbosi)
When I did mine I had the same problem. The problem was that when I played with the voltage and put it within specs I would get the code at WOT. So I lowered the voltage at WOT and then I got it at idle. So it took me a few times before I found the right voltages that didn't give me the CEL at WOT or closed throttle.
Old Oct 5, 2005 | 01:16 AM
redturbosi's Avatar
ill adjust it today when i get off and ill let you know. but why it id work out of specs of what they call for.
jdm Ef-9
10
Nov 5, 2009 05:09 AM
tazeat
10
Dec 3, 2008 09:28 PM
Darkane
Jun 16, 2008 08:41 PM
matt2001teg
Dec 19, 2005 05:51 AM
Skunk2_92gsr
Apr 2, 2003 06:55 PM
