Tial 38mm problem or no?
Old Oct 3, 2005 | 02:51 PM
SPOOLINmatt's Avatar
Default Tial 38mm problem or no?
i got a 38mm wastegate TiAL. Its been sitting on a motor that hasnt been drivin in months. when i took it off the manifold all was good, then the fire ring fell out like usual but then something wierd happened. the diaphram fell out. but it doesnt look like something broke for it to fall out, theres like a dowel that it sits on that goes up into the spring housing. i can sit it back on the dowel but i cant press it in where it will stay. is this normal. do the 38mm do this. does it just stay on from exhaust pressure hitting it as its exiting?? or is it Fux0rd.
Old Oct 4, 2005 | 04:17 AM
Default Re: Tial 38mm problem or no? (SPOOLINmatt)
bump
Old Oct 4, 2005 | 05:05 AM
RacerXI's Avatar
Pics? It's kinda tough to follow. It looks like you're missing some allen head screws, but it's tough to tell.
Old Oct 4, 2005 | 07:39 AM
Default Re: Tial 38mm problem or no? (RacerXI)
no im talking about the diaphram that vents the actual exhaust gas. theres no allen screws no where near it. its what the fire ring presses against.
Old Oct 4, 2005 | 07:45 AM
wantboost's Avatar
Who is Mr Robot?
you mean the valve... pull the top cover off and see whats up
Old Oct 4, 2005 | 09:08 AM
Default Re: Tial 38mm problem or no? (wantboost)
i dont need to pull the top cover off, it has nothing to do with this. the valve fell off the rod that goes up into the top housing. like its just pressed on it looks like but i couldnt get it to stay on there.
Old Oct 4, 2005 | 09:26 AM
wantboost's Avatar
Who is Mr Robot?
hmmm. it should be one piece, valve face and stem
Old Oct 4, 2005 | 09:55 AM
jtsquibble's Avatar
same thing happened to mine i just sat it back on and pushed the whole bov back together and put my 6 screws back in and it workd fine
Old Oct 4, 2005 | 11:45 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Tial 38mm problem or no? (jtsquibble)
its not a blow off valve... its a wastegate
Mikey3000
Jun 9, 2010 02:39 PM
Mr. Em1
Nov 4, 2008 12:04 PM
rideblitz
Oct 28, 2004 08:13 PM
busakiller
Jul 22, 2004 05:12 PM
ezark
Oct 2, 2002 12:34 PM
