how much power can a 14b make on a D16?
$4500 in a D series
i have a D16y8 that is being fully built right now, i am putting in Wiseco coated 9.0.1 pistons with rings, motor is being bored 20 over, so its the 75.5mm pisonts, tuner toys forged I-beam Rods, cometic turbo/nitrous head gasket, arp head studs, rod studs, new oem valves and valve seals...
I am going to be running a 14b on it because its from the setup i had i was just wondering how much power i can make using that turbo, and how many pounds would be ok to boost on it being a daily driver. I have uberdata that will be tuned for it with 450cc injectors and a 255ml walboro pump.
$4500 in a D series
Re: how much power can a 14b make on a D16? (fresh pizza guy)
?? any ideas? or what size turbo do you think i should run to be looking to make around 300+?
What are your goals??
Ive seen as much as 280-290whp out of 14b on a stock 2.0L 4g63 w/ supporting mods..
If u wanna do something cheap and nice..
Get a 14b turbo and put a 7cm turbine housing on it. Should be good for more towards 300whp
96gsrhatch8230
03-12-2007 07:16 PM
