my d16 engine build post..more updates soon..
Old Oct 4, 2005 | 09:14 AM
redzcstandardhatch's Avatar
something different
Default my d16 engine build post.. pics/vids.
well, my build has basically finished (long weekend of finishing up/swapping/breaking in). here is a few pics of it. using the same turbo kit i had put together last year, but with a modified drag manifold to stop creep (see video for a close up). i basically ran a tube from the merge to the elbow i had the wastegate on...and welded it all to the cast manifold. seems good. my brother did the final welding..(no pics of that...had it off due to a bit of leakage) it now looks like it came from the factory that way..he can weld cast to thick tubing much better than myself...he's a great welder. (thanks again for the help jeremy)
the turbo is an airesearch .42/.48..rebuilt (but still puking some oil once and a while, even with my restrictor setup....ran it too long without restrictor) i plan on replacing it with a holset hy35..and a bigger cam to spool that faster, along with a custom top-mount manifold i'm starting work on soon, welded by my brother. the intercooler is a spearco semi-sidemount bar/plate (old porsche upgrade)..i rewelded one end tank. i love the look of it, and it's 3'' core seems to cool everything well.
The engine consists of a stock block..honed first with scotchbrite pad and then a real hone (bought the real hone later, not pictured). The engine has ARP head studs squishing a copper sprayed z6 headgasket between the block and rebuilt/milled stock a6 head w/ a skunk2 cam gear. i plan on adjusting the cam gear a bit, when we get it on the dyno soon. a bunch of buddies from chicago are renting out a dyno in chicago for probably a whole day, so i'll spend an hour or so making a nice safe but powerful tune on this thing (Lord willing).
The pistons are SRP's , and the rods are Eagles. i got the rods and pistons from the best fricken guy in the honda performance business, Cody at Lovefabmotorsports....GREAT GUYS.. i'll be buying more from them. Rob even gave me a shirt last time we hung out at gingerman! haha. thanks guys!
Its tuned by our very own splitime and myself,using turboedit software and his wideband (in video), just for a break in. we'll be re-tuning it this weekend for higher boost if all goes well until then. its using a z6 manifold/TB, dsm injectors..stock ignition system minus the msd cap and external coil (i hate honda coils...too many have failed me)
Here are just a fewquick pictures..more to come most likely. here it is before i tore it down. looks almost identical now..just cleaner..less greasy..
here is the block, bare and dirty(even after about 2 hours of scrubbing before dissasembly (last friday).
crappy pic of my block notching for the "big" ARP 3/8'' bolt eagles.
here is the first step (not even necessary now that i bought a real hone) of honing...super ghetto, but i ended up doing it right.. the scotch brite pad left it too polished...the hone did a nice job (see assembled pic below)
here are before and after pics of the head. had about 120k on it...looking good when rebuilt. done by apex in chicago...75 bucks for a mill/new seals/uber cleaning.. super sweet deal from a cool old guy. not shown is the skunk2 cam gear a got for free...had one on an engine laying around a buddies shop.. i know the kid who technically owns the engine (but left it there for a long time now and is never going to do anything with it) and i might give him some cash...if he ever figures out i gaffled it! :wink: :-D
heres the old bearings...colors still visable..looking good too, only one score mark on one..nothing on the crank. sized em and orderd new honda bearings.. plastigauged the stuff before final assebly..the rods liked "green" bearings. tolerances were nice.
i used this clutch disc (centerforce sprung 8 puck) with my clutchmasters stage some-****.. grabs nice, should hold well. my organic disc with my clutchmasters PP never slipped with the old setup..and i tracked/draged/street drove it a LOT... this disc has only 1,000 ish miles on it...perfect basically. i sanded the glaze off the PP and the ACT lightweight flywheel, and threw it together. i like the feel a lot, even after 60 or so miles.
here is the final assembly of the bottom end..ARP rod bolts, OE seals/bearings...all new. coppersprayed z6 headgasket...(its not a blockgaurd)
thats about it for now. i have some pics of the rods and pistons..i have to sift through them though... i also balanced the rods and piston asseblies to within .4 gram of each other. they were about 10-15 grams apart. it seems to have aided in making the engine a little smoother.
heres a link to a video of it running. i'm the big guy in the yellow shirt..with the annoying voice on video. splitime is shooting the vid. you also hear blocker in the background laughing and making fun of me. haha
http://www.forgedweb.com/garbage/adams_startup.wmv
thanks to athiest for hosting the video, and Paul for hosting the pictures! updates too when i get the pictures sorted out, and re-tune the bitch... this week i'll just be driving it around, doing a light breakin. BIG thanks to LOVEFAB, and all my buddies for helping out (especially josh, splitime, john and jeremy) thanks for looking-adam
Modified by redzcstandardhatch at 8:48 PM 10/4/2005
Old Oct 4, 2005 | 09:20 AM
Tinker219's Avatar
Default Re: my d16 engine build post..more updates soon.. (redzcstandardhatch)
get that **** on a dyno you puss!
Cant wait to see that at next years WMHM! Maybe itll keep up with the K turd?
Old Oct 4, 2005 | 09:22 AM
something different
Default Re: my d16 engine build post..more updates soon.. (Tinker219)
harsh words! yeah, it'll be dyno'd shortly....hopefully a baseline after we streetune, and a full dyno tune within a month.. i'm a bit short on alloted funds for car stuff....mainly cause i went to the forged pistons instead of the vitaras....thanks again cody-adam
Old Oct 4, 2005 | 09:27 AM
EJ1 wilcox's Avatar
Default Re: my d16 engine build post..more updates soon. pics/vids. (redzcstandardhatch)
Excellent work
How much boost/power are you planning on making?
Looks like a great setup!
Tinker219's Avatar
I think youll be glad you did the pistons that are built to fit though I need to get Atheist to host some vids for me; although my site bandwidth takes up any extra "favors" Im sure...
Old Oct 4, 2005 | 09:32 AM
something different
i like athiest. he's too damn skinny though.
yeah, the pistons sound stock. no slap, etc. they were on the high side of factory tolerances (have it written down somewhere).. they were also 10 grams lighter per piston.
i plan on running it with the current turbo setup to high 200's WHP. i was making an estimated 210 whp before (creeping)... it made a recorded 185 whp at 6-7 psi, and i ended up turning it to 8-9 psi eventually.
i'm going to be upgrading to either a GT series (if i sell my house soon, and do well on it) or a holset hy35w (more likely), and a new manifold..
i'll also be upping the injector size, maybe to 550's. not sure.. maybe 700-1000 cc.. might as well!
Old Oct 4, 2005 | 10:31 AM
jaydmcrx's Avatar
best 75 bucks you ever spent was on that motor you bought from me and levi..LOL! Looks great like i said before adam. Good luck. I bet its gonna put down some great numbers.
Old Oct 4, 2005 | 10:33 AM
something different
Default Re: (jaydmcrx)
thanks sean! that engine is actually still alive...ran great when i pulled it out.
still in one piece..its now the backup. i bought this block from a guy in tenn.
also, this same thread is posted on homemadeturbo.com, and originated on ef-honda.com....they are the three sites i frequent, and it keeps me from being bored at work.
Old Oct 4, 2005 | 11:08 AM
jaydmcrx's Avatar
Default Re: (redzcstandardhatch)
Damn that motor just keeps on going. I might have to give you 80 bucks for it.
Old Oct 4, 2005 | 11:16 AM
something different
not for sale! haha
Old Oct 4, 2005 | 01:54 PM
something different
oh, sean, if you give me your ITR engine, i'll sell you the d16. deal?
haha
Old Oct 4, 2005 | 02:36 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">I think youll be glad you did the pistons that are built to fit though </TD></TR></TABLE>
Pfffttt... just because he heard how my car sounds cold.... doesn't mean they don't fit We'll see what type of numbers I can extract from it, should be fun.
Old Oct 4, 2005 | 02:48 PM
EJ1 wilcox's Avatar
Default Re: my d16 engine build post..more updates soon.. (splitime)
Do you have any pics of the modified manifold? Sounds interesting...
Old Oct 4, 2005 | 02:49 PM
splitime's Avatar
Default Re: my d16 engine build post..more updates soon.. (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any pics of the modified manifold? Sounds interesting...</TD></TR></TABLE>
Watch the crappy video i took, there is a closeup... and its fairly visible just before the camera looses focus.
Old Oct 4, 2005 | 02:56 PM
something different
yeah, the manifold should work well. the Drag is actually a pretty well designed and quality cast manifold..but they put the wastegate only on one runner..
i had to use an elbow on it to clear the 88-91 stock hood, so i just ran a tube across to kinda the back far corner of the merge...hope it works. it should
hopefully the rings seat well..its not smoking at all, and seems to have good compression..but on homemadeturbo.com, abaz said my crosshatching didnt look good enough...but it was around 45-50 degrees, and pretty rough. the assembled pic has the cylinder walls coated in wd-40, and it kinda kills the look of the crosshatch with the flash...still making me nervous..but i think its all good. well know in a few months.
Old Oct 4, 2005 | 07:50 PM
jblocker's Avatar
glad to see this done adam, cant wait to get it all tuned and see what kind of numbers you get out of it
Old Nov 3, 2005 | 05:08 PM
DualCamDan's Avatar
Default Re: my d16 engine build post.. pics/vids. (redzcstandardhatch)
looks good man, any updates on it? did you hit up the dyno yet?
Old Nov 3, 2005 | 05:16 PM
onePOINTsix's Avatar
Default Re: my d16 engine build post.. pics/vids. (singlecamdan)
hey where'd the "N/A Is BEST!" sticker go?
Old Nov 3, 2005 | 05:46 PM
something different
Default Re: my d16 engine build post.. pics/vids. (onePOINTsix)
yeah yeah yeah! its obviously NOT NA kent. haha
no updates yet power wise, sorry dan. couldnt get to the dyno yet, no time, no budget.
i did run a 13.3 on a wet track though, with a stumble in the top end (rough tune still)
REALLY happy about that.
i'm still sorting out stuff, and we're re-tuning next week most likely, but its running great, and the compression test shows its healthy, 150 across the board, give or take 2 psi.
Old Nov 7, 2005 | 01:33 PM
blkhtch98's Avatar
nice set up im looking to do the same
Old Nov 9, 2005 | 11:20 AM
DualCamDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah yeah yeah! its obviously NOT NA kent. haha
thats awesome! get that sucka tunned and lay it down, SOHC REP! how many pounds are you boostin?
are those pistons 9.0:1? did you assemble it yourself?
i cant wait to get my build going
keep me/us updated!
Old Nov 9, 2005 | 07:52 PM
something different
the pistons are 9:1 for a d16z6...so with an a6, i'm guessing about 8.?:1
we tunned a bit more tonight up to about 16 psi...but i'm getting a high RPM miss, gotta go through the dizzy and figure out the deal.
it is exactly what i wanted...a 12 second capable (almost there, but the track was wet), road course-able, daily driveable civic.
slammedef06
Jun 25, 2005 08:34 AM
FastEK9
May 21, 2004 08:57 PM
Meet07
Feb 22, 2004 10:55 PM
Boostage
Jan 25, 2004 08:19 PM
Big James
Aug 6, 2001 09:36 PM
