Boost level will not go down? even with MBC?? help Please
Old Oct 5, 2005 | 06:37 PM
Brycen's Avatar
Default Boost level will not go down? even with MBC?? help Please
Hey guys i have a question, i just got this kit installed a month and a half ago and it ran fine when i got it then all of a sudden it started boosting 10psi which it was set at 7, all of a sudden it starts boosting this amount and even with a turbo smart Manual boost controller it still is that high and it is boosting even high,what should i do?I have the manual boost controller turn almost completely off and it still boost higher even,do someone know what could be happening.Its a 94 Accord f22b1 vtec motor with full TSI turbo kit.
Old Oct 5, 2005 | 07:08 PM
B6tPoweredMx3's Avatar
Default Re: Boost level will not go down? even with MBC?? help Please (Brycen)
First off you can not lower boost with a boost controller only raise it.
Second. Is it an internal or external wastegate?
Old Oct 5, 2005 | 07:15 PM
Brycen's Avatar
Default Re: Boost level will not go down? even with MBC?? help Please (B6tPoweredMx3)
Internal, i know about making the waste gate line longer, i have not tryed that yet.
Old Oct 5, 2005 | 08:51 PM
Brycen's Avatar
need help guys BUMP
Old Oct 5, 2005 | 09:04 PM
97turbols's Avatar
what psi is the wastegate set at?
Old Oct 5, 2005 | 09:15 PM
Brycen's Avatar
Default Re: Boost level will not go down? even with MBC?? help Please (97turbols)
sapposed to be 7 but it was set when i got it and now it went up to 10 psi just trying to get it down is all.
Old Oct 5, 2005 | 09:28 PM
97turbols's Avatar
You can't make the boost go down any lower than what the wastegate is set at only up.
Old Oct 5, 2005 | 09:50 PM
Brycen's Avatar
gottcha, so basicly pull the boost controller out and just put another hose on it and call it good,Thanks alot much appriciated.
Old Oct 5, 2005 | 11:22 PM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols &raquo;</TD></TR><TR><TD CLASS="quote">You can't make the boost go down any lower than what the wastegate is set at only up.</TD></TR></TABLE>
Ive been told this also and by many others.
Weird thing is.. When I first got my car boosted. With a 38mm .4bar tial and a Generic MBC spring/ball type. I could fully adjust the boost from 1psi-20ps+
Not sure why, but it did.
Old Oct 6, 2005 | 01:05 AM
raceACCORDingly's Avatar
take out the mbc all together. if it goes back to normal then that mbc has issues.
Old Oct 6, 2005 | 03:02 AM
D@nnY's Avatar
Default Re: (raceACCORDingly)
also check for holes in the boost line going to the gate....if theres a leak it will boost more
hold your breath
Mar 6, 2007 07:47 PM
BlUAc
May 20, 2006 09:43 AM
a1320addict
Aug 12, 2005 10:47 PM
jovial111
Dec 15, 2003 04:39 PM
clean
Oct 18, 2001 11:16 AM
