Weird: problems starting car..?
Old Oct 3, 2005 | 05:42 PM
turbotime's Avatar
Default Weird: problems starting car..?
i just went out to try and start my car and it started and then like died. I started it again and it fired up but when i put it in reverse and tried to back up it would keep dropping like it was gonna die and then revn back to normal...
any idea what could cause this? I was just driving it not 1hr ago and it ran fine... it jsut seems like starting is an issue..
Old Oct 3, 2005 | 05:53 PM
turbotime's Avatar
could it be the FITV
Old Oct 3, 2005 | 05:54 PM
oscarmayer's Avatar
Default Re: Weird: problems starting car..? (turbotime)
new cap and rotor and plugs? fies my issue every time. with a hot fire box every oil change i swapped those out too. if not i had issues.
Old Oct 3, 2005 | 05:57 PM
turbotime's Avatar
all the inigtion stuff is new, inluding the dizzy itself, using bkr7e's
other ideas?
Old Oct 3, 2005 | 05:59 PM
turbotime's Avatar
my mechnic removed some sensor from the intake manifold, he said it was only used for cold start and he used some aluminum to block the hole cause it was causing a vacuum leak since it was broke.
Im not sure what sensor it was but he said the diaphram was broken.
Never had any problems starting until just today- car runs fine tho after a few seconds
running hondata, tuned
aznjay510
Apr 29, 2019 08:13 AM
Cypher0117
Mar 3, 2010 02:16 PM
DoyouVtec
Dec 9, 2005 07:15 PM
tonezilla
Sep 1, 2004 11:15 AM
SwedBoy2999
Aug 30, 2004 09:59 AM
