STR INTAKE MANIFOLD ON TURBO GSR VS OTHER MANIFOLDS
I have an STR INTAKE MANIFOLD that i'm going to be using on my turbo 2.0 gsr. I have heard that the str,edelbrock victor x, and golden eagle manifolds are the best manifolds for turbo b-series. Many people I know only use the STR and Golden Eagle. Which manifold is better between the 3? heres my setup if it helps
PRECISION SC61 63 A/R
HONDATA S200 WITH BOOST
RC 750CC SATURATED INJECTORS
GOLDEN EAGLE COMPLETELY BUILT BOTTOM END 9:0:1 CR
KMS PNP HEAD WITH THEIR SPRINGS/RETAINERS AND BRONZE VALVE GUIDES
TIAL 38MM WG
3 INCH DOWNPIPE
EQUAL LENTH TUBULAR MANIFOLD
2.5 INCH IC PIPING W/ DRAG INTERCOOLER (UPGRADING TO PRECISION 600HP)
MSD SCI/ BLASTER 2/AND DISTRIB CAP
WALBRO 255LPH FUEL PUMP
STR FUEL RAIL
STR INTAKE MANIFOLD
GOLDEN EAGLE VACUUM MANIFOLD
SKUNK2 CAM GEARS
SKUNK2 68MM TB
ACT XT PRESSURE PLATE 6 PUCK CLUTCH
ACT 12LB FLYWHEEL
JDM TYPE R LSD
KTELLER 3 INCH SS EXHUAST/ MAGNA FLOW TURBO MUFFLER
FLUIDAMPR PULLEY KIT
KOYO RADIATOR AND FLEX-A-LITE FANS
AND LOTS OF SUSPENSION STUFF
TIAL 38MM WG
3 INCH DOWNPIPE
STR FUEL RAIL
STR INTAKE MANIFOLD
SKUNK2 CAM GEARS
SKUNK2 68MM TB
ACT 12LB FLYWHEEL
JDM TYPE R LSD
Re: STR INTAKE MANIFOLD ON TURBO GSR VS OTHER MANIFOLDS (chrisgottigsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgottigsr »</TD></TR><TR><TD CLASS="quote">STR is now BDL right.</TD></TR></TABLE>
No kidding...thats why I put this little face in my post
.RTErnie
Welding / Fabrication
29
04-27-2009 07:31 PM
