can i run a gsr without an fmu
i put my turbo kit on but im not runing an fmu im only runing a exes regulator and im obd2 and i got rc 440 injectors and retarded timing
Re: can i run a gsr without an fmu (Hybrid_Coupe)
so you are turbocharging with nothing at all to regulate your air fuel ratio?
If so I would suggest parking it while you do some research. An FMU is much better than nothing, and that is still a huge cause for concern. Look into getting something that can actually tune the car for boost
Re: can i run a gsr without an fmu (ProjectDarkBlack)
you have 3 options listed from worst to best
-fmu with sock injectors
-apex'i v/safc controller and 440cc (at least) injectors
-stand alone fuel mangement/ chipped ecu and bigger injectors
you cant mix any of these together
and if you run a fmu for now make sure you run check valves or a missing link
Re: can i run a gsr without an fmu (exotik4doorcivic)
for the sake of your car buy an fmu if you HAVE to drive it. if you need it tuned call 714 590 9289. they are located in garden grove. tell them brian from h-t sent you.
spoon95eg
12-19-2005 06:15 PM
