TRANNY WAS STUCK INPUT PLEASE
first off i jus changed my tranny a few months back and it says 95 del sol on it . i dont know if its a si or dx it dosent feel much diff from my old ex tranny.........
i went to capitol raceway two weeks back and i did my burn out and staged up i was on 17" rims so i wasnt tryin to get a good E.T. i jus wanted trap 125 or higher. i took off @ 3300 rpm and started to wheel hop real bad then my car shut off n got fluded so i pushed it to the side and pulled injector clips off and cranked on it , hooked em back up and it started but the car didnt wanna move at all even if you tried to slip the clutch out it jus wanted to shut off. i was the third one on that side of the track after they sprayed bht for bout an hour so it was real stickey. so i finally got it into 2nd gear and left the track, dri=ove for bout 15-20 miles in 2nd then i tried to run it up to redline and let it coast but it then popped out of gear and now i have all my gears back and every thing seems fine.WHAT DO YOU GUYS THINKED HAPPENDED AND DO YOU THINK ITS OK???????????????
THANKS
-MIKE
THANKS
-MIKE
USDM 4G VTEC
24
Apr 17, 2003 11:57 AM
