cant get oil pressure
I just rebiult my b18c abd I am trying to get oil pressure before I start the motor and oil through my oil feed line to my turbo but it isnt making any pressure. I put on a new itr oil pump and poured oil in it when I installed it. I have cranked the car over for about 1.5 min. in 10 sec. intrervals and I havent seen anything come out of the line yet.
Re: cant get oil pressure (jtracing919)
I'm scared to start it if there is no oil pressure. I used assembly lube on everything, but I dont want to take the risk of messing someting up and I also dont want to run my turbo with out oil pressure.
Well we just did this last night , we pulled the valve cover and we cranked it for almost 4 mins total with short brakes to let the starter cool down , and still no pressure so we just started it with no valve cover on it , as soon as we seen oil shoot down on to the cams we shut it down and new we where good to go , and at idle for like 10-30 secs should not hurt a turbo , just squirt some oil into the oil inlet if your realy worried about it ,
Re: cant get oil pressure (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">Crank it with the spark plugs out</TD></TR></TABLE>
umm if he's been turning it over in 10 sec intervals im sure he has the plugs out ir at least the wires off the plugs
Re: cant get oil pressure (b16adx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx »</TD></TR><TR><TD CLASS="quote">
umm if he's been turning it over in 10 sec intervals im sure he has the plugs out ir at least the wires off the plugs</TD></TR></TABLE>
taking hte spark plugs out and having he wires off the spark plug is two diff things.
without the spark plug in the head. the engine will crank over faster since there no compression
Ummm he said pull the plugs so there will be no compression smartie pants.
Re: cant get oil pressure (jinjabred)
The motor will spin much faster with the plugs out. You can get oil to the head/turbo much quicker. thats what i meant
xkrazyxjbrkerx75
08-09-2011 02:47 PM
