compression test...
Old Mar 26, 2006 | 05:00 PM
818wHtEG6's Avatar
Default compression test...
did a compression test on my car, setup:b18c5 motor, 9:1 comp pistons, skunk 2 turbo cams,t3/t4, results were 90-95-95-90......is that normal for my setup, just started blowing white smoke out exhaust only but still runs ok till it hits v-tec then has a slight stutter....any help would be awesome thx
Old Mar 26, 2006 | 05:29 PM
onefstek's Avatar
verry verry low comp. numbers, even for a 9:1 engine. Your rings must be shot, how many miles on the motor?
Old Mar 26, 2006 | 05:47 PM
planeman01's Avatar
were you holding the throttle wide open while you were cranking it over?
Old Mar 26, 2006 | 05:56 PM
forcefed9974's Avatar
Default Re: (planeman01)
yeah that's very low. it's hard to think that all your rings went at the same time but it could be a possibilty.
Old Mar 26, 2006 | 06:02 PM
onefstek's Avatar
keep the throttle open and crank the car till the gauge does not go up anymore.
Old Mar 26, 2006 | 07:16 PM
kuja's Avatar
Default Re: (onefstek)
my 9:1 gsr motor is about 185-190 if that helps u any. I don't think not holding the throttle open is gonna make a 100 point difference.
Old Mar 26, 2006 | 07:23 PM
SpeedingHatch's Avatar
Default Re: (kuja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja &raquo;</TD></TR><TR><TD CLASS="quote">my 9:1 gsr motor is about 185-190 if that helps u any. I don't think not holding the throttle open is gonna make a 100 point difference.</TD></TR></TABLE>
It makes a significant difference. I forgot to go WOT once and was like wtf, then i went wot and the numbers came back alot better.
Plus, each gauge is different
Old Mar 29, 2006 | 07:36 PM
818wHtEG6's Avatar
Default Re: (SpeedingHatch)
ok well i figured out it was just the compressiontester itself, it was fucked up, did it again and got 175-155-155-155, and i warmed up thae car a little more......but the car still smokes, (white smoke), and i was reading that ur oil rings can go bad but u can still keep ur compression, is that true? dont think its the head gasket car doesnt overheat or anything, and turbo is fine no shaft play or oil in charge pipes......any help would be awesome thx
Old Mar 29, 2006 | 08:32 PM
SOHC_MShue's Avatar
Default Re: (HnDaCvCtYpEr)
if your burning oil it should have a bluish tint to the smoke. Your compression numbers def arent the best.
Old Mar 29, 2006 | 11:19 PM
818wHtEG6's Avatar
Default Re: (SOHC_MShue)
its only blowing white, not blue tint, and if its not that then i donno what it would be, and all these problems happend after my last run at the track last week
Old Mar 30, 2006 | 09:35 AM
SOHC_MShue's Avatar
then its coolant
Old Mar 30, 2006 | 09:54 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">then its coolant</TD></TR></TABLE>
x2
boostedteg4dr
Jan 24, 2009 03:52 PM
eg:R
Aug 21, 2008 10:55 PM
1FastCoupe
Apr 13, 2005 09:31 PM
B20luda
Jun 8, 2004 08:20 PM
ChillOutWayne
Jan 23, 2004 10:34 PM
