Hot tanking a block.
Old Mar 25, 2006 | 04:22 PM
dunkd's Avatar
Default Hot tanking a block.
If a block has RTV silicone on it, then is hot tanked, will it come off? I got my block back from the machine shop and this silicone was on it, but they said they didn't put it there.
Old Mar 25, 2006 | 07:18 PM
IN VTEC's Avatar
Default Re: Hot tanking a block. (dunkd)
Not all of it will come off, especially the thinly coated areas.
Next time, before you send any parts for cleaning, you need to razor blade off the large beads/pieces and then remove the rest with lacquer thinner and a Scotchbrite pad.
Old Mar 25, 2006 | 07:29 PM
dunkd's Avatar
I got my block hot tanked and honed and when it came back it had silicone in this spot that is circled...
and now it leaks from there.Last year after it was sleeved it was fine, now it is leaking...
I do not know who put the silicone in there. The shop that honed it said they didn't...
here's the full story https://honda-tech.com/zerothread?id=1570279
Old Mar 25, 2006 | 08:58 PM
:Josh:'s Avatar
Default Re: (dunkd)
Hot tanking a sleeved block is not a good idea. In fact all the sleeve installers warn against it as they apply silicone to the sleeves when they install them. The silicone you saw was probably from whoever installed your sleeves.
Old Mar 25, 2006 | 09:22 PM
Muckman's Avatar
Moderator in Chief
Default Re: (FourDoorLS)
That doesnt seem right. My benson block has been hot tanked twice and never had any problems. Normal engine life sees much higher temps than in a hot tank.
Old Mar 25, 2006 | 10:38 PM
aspec101's Avatar
Default Re: (Muckman)
Yeah but a hot tank has uses chemicals to clean. So, therefore it is recommended you don't hot tank a sleeved block. Since you have been lucky, does not mean everyone is.
Old Mar 26, 2006 | 05:50 AM
raiden571's Avatar
i thought u couldnt hot tank an aluminum block
Old Mar 26, 2006 | 08:27 AM
shortyz21's Avatar
Default Re: (raiden571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">i thought u couldnt hot tank an aluminum block</TD></TR></TABLE>
uh what?
Old Mar 26, 2006 | 08:31 AM
.adam.'s Avatar
u cant hot tank an aluminum block, but the method that they use to clean/degrease it is stilll referred to as "hot tanking"
Old Mar 26, 2006 | 06:06 PM
:Josh:'s Avatar
Default Re: (civicskater)
Same thing as a hot tank or jet clean minus the caustic chemicals.
Old Mar 26, 2006 | 06:08 PM
:Josh:'s Avatar
Go to GE or AEBS websites and check it out. They specifically state "Do not hot tank your sleeved block!"
Old Mar 26, 2006 | 06:59 PM
raiden571's Avatar
i personally dont see the point of hot tanking our motors. i wouldnt take the risk of damaging 1000 dollar sleeves in order to have a clean block. iwould just hand wash it and paint it, but thats just me
Rickcrx
Feb 23, 2012 05:18 PM
HyperFlow
Aug 5, 2010 11:11 AM
x91crxsix
Jul 28, 2006 10:42 AM
West Werks
21
Aug 9, 2004 10:36 PM
