turbo advice
Old Mar 27, 2006 | 10:44 AM
EJ8 GSR-T's Avatar
Default turbo advice
i keep changing the setup so i dont know which turbo to go with.
I have a gsr, built with 9:1 com cp pistons, and eagle h beams...stock sleeves, and i need to figure out a turbo to get me atlest 350whp
which one to go with?
Garrett T3/TO4E 60 Trim Turbocharger
.63 a/r or
.82 A/R or
Garrett T3/TO4E 57 Trim Turbocharger
.63 a/r or
.48 A/R
Old Mar 27, 2006 | 10:55 AM
EJ8 GSR-T's Avatar
Default Re: turbo advice (userdead626)
i wanted an sc61 but they are a bit expensive, which one of these is closest to that?
i think the 60trim 63a/r will be the best bet?
Modified by userdead626 at 2:24 PM 3/27/2006
Old Mar 27, 2006 | 02:25 PM
EJ8 GSR-T's Avatar
Old Mar 27, 2006 | 04:57 PM
Rico's Avatar
I would just go ahead a spend the extra money and get the SC 61. You already have a built bottom end so why waste money, see what she can do with a good turbo.
Old Mar 27, 2006 | 05:26 PM
EJ8 GSR-T's Avatar
Default Re: (Rico)
this is if i go with the sc61 i cant get anything better than a log manifold....cash is tight after the buildup
drintegra's Avatar
60 trim defntly at the very least. for 350 you are looking at atleast 12-16 psi depending on mani, down pipe and the efficiency of the motor.
My st up has the T3/60-1 63AR this should get me to 330 stock motor at about 10psi 3 dp and tubular mani.
Old Mar 27, 2006 | 05:40 PM
EJ8 GSR-T's Avatar
Default Re: turbo advice (drintegra)
hmmmm, so whats my best bet if i want a new turbo for about 600?
Old Mar 28, 2006 | 04:09 AM
Rico's Avatar
man you should make plenty of power on a log style manifold, just save a little more money and get a sc61 or get a gt30r. Do it once instead of 3 or 4 different times and waste money and time. pm arturbo for prices he is very helpful...
turbosol_16
Dec 27, 2006 06:41 AM
hondahatch741
May 30, 2005 12:36 PM
JdM_Eg_6
Sep 13, 2004 04:27 PM
reaction360
Jul 2, 2004 01:31 AM
M.A.R.C.
Jun 10, 2002 03:23 PM
