At what point does te stock fuel lines max out?
Does anyone know around what point does the stock tank to rail fuel lines max out? I searched but didnt find too much, although I'm sure this has been covered once or twice before...
TIA
TIA
Re: At what point does te stock fuel lines max out? (.nate)
http://www.evans-tuning.com/tech8.html
this should give you some information
Re: At what point does te stock fuel lines max out? (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">that says stock is only good to 500hp, that cant be right.</TD></TR></TABLE>
def not right.
ive tuned many cars that made over 600 whp on stock lines.
def not right.
Re: At what point does te stock fuel lines max out? (Mase)
thats a good point i dont doubt the lines abilities to hold to the levels that youve tuned at and i plan on keeping my stock lines for now with my 600hp project but in the end id be happy to have the peace of mind upgrading once i reached levels of horsepower that high with extra fuel pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">that says stock is only good to 500hp, that cant be right.</TD></TR></TABLE>thats is correct! and it all depends on your tuner some are very a.r and will not attemp to make that power without a upgraded -6 line but stock is fine. i have seen numerous cars between 5 and 6 hundred whp dynojet on stock fuel lines
Re: (.nate)
how about a dash 8 fuel line and be done with it. I made 623 with stock line from tank to filter and a -8 from filter to rail. dont liek that dinky rubber line.
Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate »</TD></TR><TR><TD CLASS="quote">Thanks for the replies!
Around how much rail fuel pressure did you guys making in excess of 600 have to end up running?</TD></TR></TABLE>im running a straight an fitting out of my fuel filter and a -6 line from the top of my filter to the fuel rail and tuned with 48psi of fuel pressure
jisu009
11-28-2003 06:03 PM
SIReg9
09-29-2003 04:51 AM
