Important finding about adding oil during compression tests...
As far as I always thought, if the numbers went up with oil in the cylinder during a compression test it was bad rings/ringlands for sure.
WRONG
If you have low compression, your block might be fine! It could be in the cylinder head.
If the valves aren't seating properly, you will loose compression and burn oil, just like having bad rings or cracked ring lands. Adding oil to a compression test can help seal the valve seat, rasing compression temporarly
So before you yank the pistons out of what could be a perfect block, check your head
WRONG
huh. Ignorance at its best...hehe j/k.
Adding oil doesn't show your head is fubbared. A leak down test is the ONLY way.
The oil test will ONLY test for how well the rings are sealing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">huh. Ignorance at its best...hehe j/k.
The oil test will ONLY test for how well the rings are sealing. </TD></TR></TABLE>
If the oil test shows higher compression, it could be the valve seats, not the rings!
either way compression tests suck, the only real way to know anything is to do a leak down test
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">yea, how much oil are you pouring in?</TD></TR></TABLE>
like a capfull
it raised compression in my #3 from 90psi to about 130psi
the rings and block were fine, it turned out to be a bad valve seat
like a capfull
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">
A cap full of oil shouldn't make any difference with the valve seat.
did you do the compression test with this same block, AFTER you "fixed" the seat? That is the only way you could say with any such evidence that it actually was the seat.
How exactly are you determining that the rings are fine?
A good rule of thumb from my experience is...
Compression test to check the condition of the block
Leak down test to check the condition of the head
Of course either test can tell you somethings wrong with the head, block or both but mainly thats how they should be approached.
</TD></TR></TABLE>A cap full of oil shouldn't make any difference with the valve seat.
no.....
</TD></TR></TABLE>no.....
this isnt true either other then the fact that it will loose compresion.... it will not burn oil from this and will not be just like a cracked ringland .....
</TD></TR></TABLE>this isnt true either other then the fact that it will loose compresion.... it will not burn oil from this and will not be just like a cracked ringland .....
interesting, i did the oil drop thing too and my #4 compession went from 90 to 130 as well but my dad thinks its the rings, im not burning any oil though. just lost compression on the #4. but if you pull a sparkplug wire out the #4 when its running it doesnt do much and wehn you pull any other it almost wants to die.
What do you think is wrong with mine then? i havent driven it for a month now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR »</TD></TR><TR><TD CLASS="quote">interesting, i did the oil drop thing too and my #4 compession went from 90 to 130 as well but my dad thinks its the rings, im not burning any oil though. just lost compression on the #4. but if you pull a sparkplug wire out the #4 when its running it doesnt do much and wehn you pull any other it almost wants to die.
rings, and/or ring lands. it also doesn't have to burn oil for the rings to be fubbared. that just means the oil ring is doing its job, and your valve seals are working.
</TD></TR></TABLE>rings, and/or ring lands. it also doesn't have to burn oil for the rings to be fubbared. that just means the oil ring is doing its job, and your valve seals are working.
dame-ningen
Apr 24, 2009 03:45 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Ri5e
Jun 20, 2002 06:57 PM
