GSR pinging
Old Mar 24, 2006 | 02:25 PM
Integra21's Avatar
Default GSR pinging
Hello Everyone,
My GSR has just recently started to ping at about 9psi, which it was tuned for. I have gone through a few tanks of 93oct so its not a bad batch of gas, i JUST put NGK 7 plugs in at .030 and can not figure out why it is pinging.
the engine has 26k miles on it. all original
Thanks
Old Mar 24, 2006 | 02:28 PM
RTW DC2R's Avatar
check your timing and are you running a w/b?
Old Mar 24, 2006 | 02:39 PM
Integra21's Avatar
Default Re: (RTW DC2R)
im not running a wideband and i too believe its something with the timing because i dont think my tuner changed the timing at all when we went from 7-9psi
Old Mar 25, 2006 | 08:35 PM
Integra21's Avatar
Default Re: (Integra21)
any other ideas?
the timing does need to be retarded more for added boost correct?
Old Mar 27, 2006 | 08:51 AM
Integra21's Avatar
Old Mar 27, 2006 | 08:53 AM
Sz28r's Avatar
Just an idea - - put the old plugs back in and see if that cures it - - that would rule out and differences in tanks of gas.
Old Mar 27, 2006 | 10:08 AM
Integra21's Avatar
Default Re: (Sz28r)
it did the same thing with the old plugs
*that was the reason for trying new plugs anyway in addition to they were old
Old Mar 27, 2006 | 10:38 AM
onefstek's Avatar
check your cap and rotor
Old Mar 28, 2006 | 05:43 AM
Integra21's Avatar
Default Re: (onefstek)
it only pings when the boost is turned up past 7.5psi.... retune?
Old Mar 28, 2006 | 06:37 AM
Integra21's Avatar
can someone please confirm what i have read, that the timing needs to be retarded "x" degrees for each added psi of boost???
Old Mar 28, 2006 | 08:43 AM
AbitAvenger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">can someone please confirm what i have read, that the timing needs to be retarded "x" degrees for each added psi of boost???</TD></TR></TABLE>just ask your tuner and if he doesn't know what your saying then find another tuner
Old Mar 28, 2006 | 02:34 PM
Integra21's Avatar
Default Re: (AbitAvenger)
i would just like to know for sure if this is correct
Old Mar 28, 2006 | 02:40 PM
nonvtecD's Avatar
yes, more timing without more fuel is going to mean pinging, go get tuned.
Old Mar 28, 2006 | 06:32 PM
Integra21's Avatar
Default Re: (nonvtecD)
yea the thing is it was tuned but i dont think the timing was changed at all
Old Mar 28, 2006 | 06:39 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">yea the thing is it was tuned but i dont think the timing was changed at all</TD></TR></TABLE>
What do you mean you don't 'think' the timing waa changed? Were you present when the boost was increased on the tune? Did you see or talk to the tuner about the timing at all? Have you asked your tuner exactly what he did? Are you sure what you're hearing is infact ping and not some sort of metalic rasp from something loose in the engine bay?
Old Mar 28, 2006 | 07:08 PM
Integra21's Avatar
Default Re: (VTC_CiViC)
im positive the timing was not changed seeing as the boost controller wasnt working for the street tune and we rigged something to the turbo would make 9.3psi on the dyno.
pinging = sound of BBs rattling around at WOT at high rpms
also i know its not something in the engine bay since it only happens on higher boost levels
Old Mar 29, 2006 | 11:07 AM
Integra21's Avatar
anyone else?
Old Mar 29, 2006 | 02:11 PM
VTC_CiViC's Avatar
First you said it was "tuned for 9psi", but now you said the controller wasn't working during the street tune so you rigged it at the dyno, correct? So at the dyno where you rigged it, you heard the audible ping? Was the tuner present or were you on your own? If that's the case then the simple answer is.. stop pushing so much boost untill the map is modified to compensate. As it is you might have already damaged the pistons more than you think..
Old Mar 29, 2006 | 03:05 PM
Integra21's Avatar
yea it was "rigged" for 9psi but the tuner did it and it was tuned for that boost amount, but only on the dyno and the timing was not touched after the boost was increased.
how would i be able to tell if the pistons are damaged? leakdown? compression test?
btw drives fine at 7.5psi...
everythingwentblack
Mar 26, 2009 11:21 PM
92integraVTECgsr
Sep 26, 2005 04:01 PM
prelude9999
Dec 2, 2004 09:53 AM
Pepsi90919
Oct 17, 2002 10:12 AM
Sh4rky
Apr 2, 2002 01:34 AM
