anyone who has installed the endyn breather with the motor in the car
any advice? i'd like to avoid removing the intake manifold. fooled around with it a bit today, looks like a wire-bracket can be taken off the alternator to make life a bit easier...
i'd really appreciate any thought anyone can contribute
Re: anyone who has installed the endyn breather with the motor in the car (yehiknowrite)
if your only taking it from the block in one spot, use the port on the passenger side
Re: anyone who has installed the endyn breather with the motor in the car (adictionbass)
what in the sam hell are you doin? ha ha just jack the car up, take off the IM support bracket and stock breather box. Make sure you buy a 14mm allen 1/2 drive socket. You need about 1 1/2' - 2' of leverage to get the plugs out easily. I did it last week on my friends car.
Re: anyone who has installed the endyn breather with the motor in the car (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack »</TD></TR><TR><TD CLASS="quote">what in the sam hell are you doin? ha ha just jack the car up, take off the IM support bracket and stock breather box. Make sure you buy a 14mm allen 1/2 drive socket. You need about 1 1/2' - 2' of leverage to get the plugs out easily. I did it last week on my friends car. </TD></TR></TABLE>
+ 1
youll need to remove anything coming out of the oil pressure sending unit spot along with the oil filter
+ 1
Re: anyone who has installed the endyn breather with the motor in the car (99B16Si)
thanks for the input.
the passenger side shouldnt be a problem at all...the driver's side looks like it may give me a little bit of a headache.
i appreciate the advice
Mr. Badwrench
i did mine with the intake off. the hardest thing is getting the plugs off. it isnt that bad.
1 Post
I did it while i was doing an intake manifold swap, good luck when installing it. i have to do one from the bottom for a friend in a couple weeks :-/ post up what you ended up doing.
///EJ6POWER
07-09-2010 11:36 PM
