Fluidampr pulley will not fit
I have a B-series race fluidampr pulley and for some reason it will not fit onto the crank. I went on the website to make sure that it was the right part number and it was. I want to know if there is a trick on putting this on or can I sand the inside of the pulley.
Re: Fluidampr pulley will not fit (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">dont they need to be pressed in?</TD></TR></TABLE>
Yes they do.
Poster: Are you saying that the od of the dampener itself does not fit, or that it is to wide to fit between the engine and the chassis or that it does not slide on to the crank???
If the problem is that latter then you will need to use the original pulley nut to "press" it on, then use a new oem nut when you torque it down. GL.
Yes they do.
epeen
08-04-2006 01:34 PM
