Need Help Hooking Up Oil Lines
well imma be boosting in about a week or so, but i am having a dilema here, i need to hook up 3 things, oil pressure gauge, oil pressure sensor, and oil feed line, and thing is i dont not want to use a bunch of Tee's off the original oil tap off the block, too much weight and vibration might cause it to break off into the block, which i do not want to have to deal with in the future, so i wanna do something to prevent it, i saw this link and i wanna do it this way, but there only using a Tee for 2 lines, i need a brass block that has 3 holes, does anyone know where i can get the line and all the fittings (thread pitch, etc etc) for the back of the block to do this set up? your help is greatly appreciated, TIA
http://www.theoldone.com/articles/oilpressure/
https://honda-tech.com/zero...age=2
go through that thread, it should tell you everything that you need.
jsnm
Mar 31, 2007 04:17 AM
