Plug reading assistance, looks like detonation?
Checked my plugs after a WOT run fom 1st to the top of 3rd gear.
shut it up, coasted off the street and pulled my #3 and #1 plugs..
heres wut they look like..
car makes great power,
last comp test a few weeks ago was 185 across the board.
d15b vtec, jrsc 9psi, crome.
2step colder ngk plugs
top 2 pics were in the sun, bottom pic in the shade
Re: Plug reading assistance, looks like detonation? (Tad)
Whats your timing look like? I tuned a boosted turbo d15b last week using a knock detecting device and it didn't want anymore than 16-17* total timing at 10psi. Anymore timing and I was picking up slight knock. I have noticed similar amounts of timing having to be pulled out on a few recent z6's as well.
Re: Plug reading assistance, looks like detonation? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">Whats your timing look like? I tuned a boosted turbo d15b last week using a knock detecting device and it didn't want anymore than 16-17* total timing at 10psi. Anymore timing and I was picking up slight knock. I have noticed similar amounts of timing having to be pulled out on a few recent z6's as well.</TD></TR></TABLE>
yeap, and on a JRSC itll want less timing due to IAT's w. no pre/after cooler.
plugs are 2step colder from stock sohc plugs.
i forget the exact part number though. bcp something.
yeah i guess it must be the timing,
was hoping it wasnt though. as the more timing it gets the better it feels.
I dont really have jack squat to monitor this,
just my ear and plugs.
could really use something that could tell me iat's, egt's, af's, etc.. without clutting up my car with a million and one gauges
yeah pretty sure thats wut they are.
i was very thorough picking these plugs, they aren't the problem.
I guess I can just turn it back at the dizzy, which has been turned forward some sicne it was tuned way back when..
i'm kinda thinking about just getting one of those rom burners, a wideband, and egt, and tuning it myself tho.
never done it before though.
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">plugs are 2step colder from stock sohc plugs.
could really use something that could tell me iat's, egt's, af's, etc.. without clutting up my car with a million and one gauges</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1555006 try this out. They work awesome for me detecting knock. Also i cant stress enough how important a wideband is. Without that you really cant do ****.
Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">BTW those are probably the best looking pics i've ever seen someone on this site post of their plugs </TD></TR></TABLE>
yeah i know! Nice pics!
I tried posting pics of mine once and it looked like i was holding a cat turd in my hand.
You should try that link Matt just posted. That seems to work well.
thanks, i know my way around a camera, haha.
I'm wondering still though, if this a result of lean a/f or timing.. It's wierd, I started hearing some pinging recently nothing changed tuning wise!
Any recommendation on a CHEAP wideband and burner combo?
I've got an adjustable fpr too.. I wonder if adding fuel there would help
Re: (Tad)
the plugs seem to of been reading a good fuel mixture. Just most of the soot ring has been disfigured from detonation.
I picked up a Innovate Wideband for 350shipped but you could get a PLX for cheaper. The PLX also is easier to mount and setup for keepin in a car you DD.
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">thanks, i know my way around a camera, haha.
I've got an adjustable fpr too.. I wonder if adding fuel there would help</TD></TR></TABLE>
it could be many things causing detonation. You will need a wideband so you can at least single out that factor. Then look into timing. If you want a cheap burner go to moates.net and get their burn1. Its compact and much much easier to use then that willhem burner. If I were you though I'd spent a little extra cash and maybe shoot for an ostrich from moates instead. Tuning without some kind of real time programming device will make you want to cry.
Re: (Tad)
I'm wondering still though, if this a result of lean a/f or timing..</TD></TR></TABLE>
Timing. The A/F appears to be fine(mixture shown on base ring) but, there is definately to much timing in the tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote"> It's wierd, I started hearing some pinging recently nothing changed tuning wise!</TD></TR></TABLE>
Could have been a bad tank of gas.
ok thanks guys,
i'm checking moates.net right now
and i looked into plx products.
looks like they have a datalogging computer thingie too!? anyone seen this?
will it work in conjunction with crome?
seems like its exactly what i need, gives me one display showing iat, egt, af, etc..(i hate clutter)
https://honda-tech.com/zerothread?id=1179346
