GT2871R on B16A2
Old Mar 24, 2006 | 02:15 AM
kebroz's Avatar
Default GT2871R on B16A2
hello, excuse me for my language, i'm french .
the famous GT2871R with only .64A/R exhaust, is not too small for a B16A2???
what is the max boost possible?? (internal little WG "boost creep")
what is the power potential with 12~15 psi (if this boost is possible)
i have 550cc injectors, neukin setup, crome pro with a ostrich, wiseco 9:1 pistons, eagle rods, block guard, cam gear etc etc..
thank you very much
Modified by kebroz at 7:19 AM 3/24/2006
Old Mar 24, 2006 | 06:22 AM
kebroz's Avatar
Default Re: GT2871R on B16A2 (kebroz)
nobody??
bump!!!
Old Mar 24, 2006 | 06:37 AM
T3T495GSR's Avatar
I think that is the PERFECT turbo for that setup, especially if you are using it for a daily driver
Old Mar 24, 2006 | 06:47 AM
kebroz's Avatar
Default Re: GT2871R on B16A2 (T3T495GSR)
thank you, yes is for daily drive, i looking for boost at all rpm, back pressure is not a problem if i tune my cam gear for minimise the overlap??
thanks again
edit: my goal is 320~350 whp maximum, how much boost i need??
Old Mar 24, 2006 | 01:33 PM
kebroz's Avatar
bump!!
Old Mar 24, 2006 | 01:38 PM
Fenrir51's Avatar
Over 1 bar most likely...
Old Mar 24, 2006 | 01:42 PM
kebroz's Avatar
Default Re: GT2871R on B16A2 (Fenrir51)
thanks i post my dyno when my car is properly tuned
Old Mar 24, 2006 | 05:43 PM
abnaasefmb's Avatar
i have the .86 one, and it takes a while to build boost. i think the .64 would have been better suited for the small b16. i'm only running about 9psi right now because it stock right now.
Old Mar 24, 2006 | 05:52 PM
American.Graffiti's Avatar
Default Re: GT2871R on B16A2 (abnaasefmb)
i do know if you can go up to 15psi on a stock bottom end b16a2. Import Racer took theirs to 14.7 i believe.
Old Mar 25, 2006 | 02:26 AM
kebroz's Avatar
Default Re: GT2871R on B16A2 (Falkien)
Thank you , the opinions are shared http://forums.evans-tuning.com...=3331 if somebody else has an opinion or a persone which uses a housing T25 exhaust with .64 on B16, thank you
Old Mar 25, 2006 | 12:39 PM
kebroz's Avatar
bump!!!
blitzman
Engine Management and Tuning
Jun 28, 2017 01:00 AM
EARLdaSQUIRREL
May 5, 2009 05:42 PM
EX-T
Mar 29, 2006 09:06 PM
Talon12bp
Dec 2, 2003 07:33 PM
djnikko
Aug 14, 2003 03:55 AM
